will a set of 15x7.5 with a et35 offset fit a 6n
will a set of 15x7.5 with a et35 offset fit a 6n without any arch work being needed?
sorry if it is a dumb question i get really confused with the offset and all of that
  • Views 695
They should fit under the arches, may need slightly stretched tyres, maybe 185s.
They will probably scrub if you are very low, but that could be solved with arch work.
ok cool, I am not thinking about going too low so hopefully they should be fine then. Thanks for the reply
