A quick mk3 polo question
Just noticed that on some mk3's there is a peice of black infront of the back bumper, kinda on the arch.
Can anyone tell me why? I've circled the bit I'm on about :)
Hope the people dont mind me using their pics...
  • Views 1k
I think, but dont quote me, that they were on standard but some people take them off :lol:
Either that or its to do with spec :)
Its a arch "guard" but the amount of crap that gets trapped behind it is stupid.
Only has 2 rivets and a little clip (sits behind the bumper mount) holding it on. I think the Fox didnt come with them, also on the fox the front bit on the rear arch was only glued on, all other models have pins holding it in, hence why there normally left on when the bump strips are removed.
Edited by Cymro
So is this easy to remove, do you have to remove the bumper to do it?
Cheers :)
no mate no need to remove bumpers, i took mine off and there just held on with pop rivets, you can either drill them out or do what i did and just got a chisel down the side of them and knock the rivets off, then it just pull off and you can pull the rest of the rivet out, although it does leave two holes in the arch but you wouldnt notice unless you got real close :p
My polo fox had them, and the arch trims infront the wheel have got little clips which go into holes.
