my next engine
Hi guys. So currently have my gt which i love but as i live in ireland and they're so rare i kinda want to keep mine pretty much as is and not do an engine conversion. I have an itch for a track inspired polo though,something with mad coloured wheels,maybe stripped out,rollcage etc..think i'l go mk3 again but wondering what engine to do?
Have a craving for a g40,but also wondering about an afh on carbs,or a gt engine on carbs. What would people recommend? i know about charger rebuilds and all the expensive aspects of a g but still kinda want one.how do carb'd afh's move? how easy are parts to source? cheers,Baz.
  • Replies 12
  • Views 1.3k
you could try carbing the GT engine first, and if you get bored move to an AFH?
could try that act, any idea how carbd gt's compare to standard?
well worth it imo, need to be setup to get the full potenial which my GT hasnt had done yet.
They can see 100bhp with and exhuast ect.
Don't bother with a GT mate, the reason I say this is you will spend a shit load getting it set up right then have to spend it all again when you decide its not enough and want a AFH.
The afh has 100hp as standard, the GT lump will always be chasing the afh in terms of power gains.
16v tbh.
I made the mistake of putting a GT into mine, with full intention of modding that. Until i saw the light... and bought a 1.6 16v :lol:
ah, but he can just bolt the carbs on gt..
instead of faffing around with an engine conversion.
Id do it if i could afford it though :S
16v tbh.
is it fitted yet toby
yeah but if he then decides that isn't enough power he has to still do the engine conversion and pay out all over again for different manifold and getting the carbs properly set up for the new engine. if he's craving for a G40 then i just can't see a gt lump cutting it, even with bike carbs. the afh on well set up carbs will give the same kind of power as a mildly tuned G40, you'll have to push very hard to even get standard power out of a gt lump even with carbs.
16v tbh.
Is it fuck :lol:
I was previously running a 1.6 version of a carb'd AFH and it was excellent. Slightly flawed in that the cam profile didn't make the best of the torque-strong stroke compared to an AEE,and the stroke continued to mismatch the cam as the revs peaked.
Fast none the less,but i knew it could be more efficient with a more appropriate cam profile.
So now I've bike-carb'd a 6n2 vvt GTi head,meaning cams designed for the stroke,and vvt cams at that. I've used the bottom end too,as the ally blocks i used before weren't up to the job. At first i thought i had poorly bedded rings,but the second one confirmed the block was flexing and the very long M9 head bolts required to put an AFH head on an ally block were too stretchy as a result of their length.
Now it has a better compression ratio too,as the previous one was too high.
Its not a straight forward bolt together job,the carb'd GTi, but it aint far off. The ignition leads weren't long enough, i also needed to machine the head and inlet cam to take the TCi-H distributor which is the main issue,the gearbox needed an anchorage lug machined off,on top of the usual engine mount modifications etc (i forget about things like 6n starter motor adaption,swapping oil/reverse-light sensors/switches but its all minor stuff).
Its not on the road yet,but i can still put it forward as an option,as I've done it.
Cheers for the suggestions guy's..certainly got me thinking. keep them coming. ;)
Sounds like a serious project Mikey,i'd like to undertake something similar but i'm not quite at that level yet..one day.;)
