DIY mk3 tailgate glass swap?
Has anyone tried this? I'll either be fitting tinted glass to my tailgate or respraying a pre-tinted tailgate a different colour so either way will want to remove and replace. If you can buy the right glue (?) it looks like it would be pretty easy (it looks a lot easier than the front windscreen and rear sides, all of which I've successfully replaced). The tailgate will be off the car.Thanks for any info!
Ray
  • Views 977
i know its off topic but since you have already done the others, are the side bonded in? cheers and sorry to be a pain lol
Edited by Jay_S
No the sides are just like the front windscreen - tight fit rubber seal all round. Piece of string and two people and it's not too bad, but still not a pleasant job!
The rears the only one bonded in :)
I cant see getting the rear one out and in again being very easy at all - why not just mask it up?
Well it depends what's meant by bonding I suppose. If it's some kind of glue that can be cut out and re-glued then it seems dead easy to me. Much easier than the rubber seals. Maybe I'm missing something?
I could mask it up but if I can feasibly remove it I'd rather do that and satisfy my perfectionism :) (colour change to white with masking is bound to miss a bit)
Edited by Ray2k
I've not seen a mk3 one up close
winscreen fitter either use a knife or some wire poked through and then a handle on each end and used to saw at the sealer
once its out trim off the excess sealer with a knife
you can buy windscreen adhesive on ebay ...cut the nozzle to lay down a upside down V shaped bead
Yes this is exactly what I was expecting, which seems pretty easy to me. Should have many more options now :)
