Polo 9n3 Rear - View Mirror
Hey all,
I was cleaning my car this morning and i took the rear view mirror off in order to give it a proper clean.......But now I can't seem to get the mirror back onto the bracket. It's affixed using a ball and socket joint; i've taken the bracket off the windscreen to avoid cracking it out of sheer frustration at the fact that i can't seem to get a mirror on a simple bracket?
Any ideas>
Thanks in advance
Goose
  • 9 months later...
  • Views 871
Did you ever get this back on? haha!
I'm in the process of painting mine.. and only got the mirror off.. and the wee arm is still on the windscreen.. how does it come off?
You turn the base I believe. If you leave it in situ and push the mirror back on it there's a good chance you'll break your window (i did)
Well guys I got it off no bother, should it twist back on easy enough.
Getting a black 9n3 one from the scrapper! Never doing this again!
Should do yes, but is still a underlying threat of a broken window tho.
