Storage for long periods
Yo,
Not really sure which forum this should've gone in, but i think this one is most suitable out of all the others.
So yeah, obviously my car's going to be off the road for at least a year, and it's going to be sat in our double garage for that time.
What i need to know is how to keep it in good condition for this period of time. How will i protect the paint? How can i stop it from rusting? Will the fuel in the tank be spoilt after a year? Will it need any bleeding and cleaning out in the fuel lines etc? Just general long time storage things that will stop it from deteriorating...
Thanks a lot! :D
  • Views 956
You won't stop it rusting mate, its a 6n :lol:
Just keep starting it up and leave it to run up to temp every few weeks, disconnect the battery when not in use. If its in a dry garage I wouldn't worry too much about the paint but if you wanna be safe buyback car cover for it to keep any dust and shit off it, give it a real good clean, wax and make sure you get any shit from under the arches or other places that it might gather and hold moisture in.
Sweet cheers for that... What about fuel? Will that just go all shitty or will it be okay? If not there's a full tank worth of mower fuel lol
if you go to a lawnmower shop they will have petrol stabilizer and that should stop the petrol going 'off'
also it might be a good idea to give it a good service so the engine is full of clean moisture free oil.
I'd go with all the advice so far given. It depends whether you are going to be around for the time the car is off the road or not. If, for instance, you are going to be working abroad for the time, I would in addition to thoroughly cleaning and waxing the car, changing the oil, adding fuel stabiliser and covering it with a dust sheet, put it on axle stands to take the weight off the tyres. They get a 'set on them if stood for a ong time. Also, take the battery off and store it somewhere where it wont encounter frost. Also, make sure that the cooling system has sufficient antifreeze in it and drain the windsceen washer bottle(s). we might have another winter like the one we have just had!
Cheers David, nice and concise :D
Another one - keep the handbrake off!
