Mk3 polo large steering spline to small spline?
just thought id stick an old steering boss and wheel on my polo, but when i took the wheel off, the spline is bigger than my mk1 golf. But it looks as though it has an adaptor on it, from small sline to large? can this come off and how!?
  • Views 1.5k
Only way to get it off without fcuking up the column is to use a hub puller, even then it can be a bit of a biatch as theres not much for it to grip onto.
Edited by oldeboi
You will need to remove the column switches before you do this.
remove the column surrounds and use an angle grinder from 2 sides. put a big enough nut and washer on to catch it if it wants to shoot forward as it is spring loaded.
i did this when i fitted a small spline steering wheel boss to my g40. and the piece you cut off is availible to buy again from vw if you want to put it back at a later date
