6n2 Rear Badge
how easy is it to remove the rear VW badge form a 6n2?
is it just pins which you can pop in and out? or does it need to be snapped out and re-glued?
cheers! :)
  • Views 2.4k
The VW emblem is stuck on with sticky pads. Just use some bug and tar remover or dental floss to 'cut' it off, or if you can, prise it off with your fingers.
To stick it back on, just use the number plate foam pads from Halfords.
If you are lookin at debadging ill warn u before u take of vws ultra sticky pads (lol) the emblem is imprinted in the body work so when it comes off the boot where it was is a circle shape and looks quiet ugly unless smoothed out ;)
cheers, i'm not looking to de-badge it mate, just wating to paint it to match my front badge :)
