a warning to all concidering an afh conversion...
any one sticking a afh in an early polo should be aware that the sumps sit sit a little low
:lol:
  • Replies 40
  • Views 2.8k
fucks sake :lol:
What damage has it done? I'm welding some plates onto the bottom of mine.
it's gone exactly the same as it did on the one at action toby, at the back right next to the sump plug
and after
i'm fitting the sump and pick up off the mk2 when i do that one to give some more clearance and i'm gonna be welding some thick plates on it as well. i'd advise any one doing this sort of conversion to at least plate up the afh sump before fitting the engine because it's such a shitty job to do once it's in the car. the car has been raised and bigger wheels fitted since the last time it happened too, i thought i was safe :lol:
Edited by McLOVIN
fuuuuck!
ouch! glad I've got a mk3 sump and oil pickup pipe on the way :/ bleak times dude!
would the mk2 stuff work or not?
MK3 sump is tempting me now haha.
Would also solve the subframe clearance issues.
The thing that confuses me though. Surely it has a deep sump because it needs that much more oil? over the MK3 engine.
So, could this not cause oil shortages when its all circulating around the engine?
Also, could cause cooling problems? Less oil will get hot quicker.
I've been thinking that, gonna put a cooler in i think, that might solve some issues.
It'll probably cause a shit load more though :lol:
I'm sure i seen somewhere on here a guy chopped and welded his to shorten it
i could well be wrong
Funk Guy! That's not good. Bloody messy job as well
Toby/Salty - adding an oil cooler would obviously cool the oil but also give a bit more oil capacity I suppose - maybe half a litre?
That was also in my thinking :) guess we'll have to see what happens, i have been debating seeing how close it is and maybe modifying, but looking at them pics, i think ill go with a mk3 sump and avoid that!
But it would be circulating around the cooler, or not at all if it has a thermostat. So it kinda voids itself out.
I've heard people mention oil starvation being a problem with the AFH's too.. which makes me a little wary. Specially as i wanna use mine on a lot of trackdays, gets abused to the max.
What's the cause of the oil starvation though? Weak pump or the oil being sloshed to one side of the sump going around corners? Baffled sump would solve this.
Is the Mk2/3 sump & oil pump a straight swap for the AFH items?
I've no idea on the reason tbh lol. Just remember reading it somewhere.
Pretty much, yeah. I think theres 1 bolt that you cant fit.
Just have to modify the dipstick IIRC
i was told it was a straight swap on to early AFH's but later ones used a different design pump or some thing?
just make sure you keep it topped up towards the top marker on the dipstick? tbh i can't see it being an issue on day to day use but if you were to use it on track days ect then like cheys says baffle the sump?
Just looked in Dans thread to see how he did his..
AFH sump its got to be for me, the oil pump is completely different. Like.. nothing alike at all haha.
I'd need to modify the AVY pick-up. I'd rather just weld some shit to the sump.
Its quite likely that the sump saved your gearbox.
I've ran a few 6n/2 engines and never scraped a sump. If you're running ridiculously low then you're gonna have issues.
Fitting an AFH wasn't the problem.
Scraping the floorpan was the problem.
damn thats bad, you should fit hydro's or something so that you can raise it when needed, o wait xD
nah neither of those were the problem, my problem is i drive it as if it's not a lowered car :lol:
it hadn't actually ripped open or owt, it has worn through over time. i think most of the damage has come from having to park the car half on the path outside my house. the path has started to wear away making it lower than the curb so if i misjudge it the sump scrapes the curb as its sitting above the level of the path.
if i took my time about parking up i wouldn't have that issue, but i refuse to be one of these people that holds every one up because they choose to drive a lowered car, same with speed bumps :lol:
Hold everyone up? Because you get really bad traffic and that on your road Guy :lol:
I find it funny holding people up on speedbumps :lol:
toby you don't know my neighbours, my mate had only parked in the road for about 30 seconds while his brother ran up to knock my door and she was out going ape shit at him :lol:
the less time i'm blocking access to their drive way the better, can't be arsed with her shouting her mouth off again the crazy bint :lol:
hahaha my mate says people have to respect him as with every other road user, it is funny how the exhaust catches on every bump though xD
and tbh having low and loud cars is safe! if your low you cant speed everywhere over everything, and if you have a loud exhaust or supercharger people can hear you coming, unlike modern day cars that are dead silent and you can do 60 over bumps with ease
Well dont be silly and have its arse on the floor then.
just :lol:
guy, you are clearly a pikey fairy and your car is spanked. whether it was an afh or a regular mk3 lump, you would have invariably ended up in the same situation.
admit it you love spilling your load on the public highway!
