Mk3 Door handle replacement
High guys I've got a mk2 golf passanger side door handle to replace the one on my mk3 coupe as theres a big crack in the plastic casing/trim :( (mk2 golfs & mk3 polos deffo have the same door handles dont they??)
I'm happy with how to swap the handles over (haynes manual FTW!) but how do I transfer the locking barrel? Is this an easy job?
  • Views 985
Come on guys its not that hard! you must have an answer for this!!!
It's a 2 sec job. You just undo the star head screw inside the handle then push it out catch the V shaped bit that moves up and down for the door mechanism and the wee spring behind it. Andvyeah the handles are the same but if your using a rear smooth golf one you need to change the flipper for a polo one but you just knock the pin out to do it.
Edited by genesisGT
Thanks alot Richard, you are the never ending fountain of Polo knowlage :D
