6N AEE R6 carbs, final dyno result...
Right guys, after making the slow, painful miles to run the engine in (approx 600 on mineral and 500 on part synthetic)...
...my final dyno result came back today from a proper setup:
From 117bhp @ 6,050 rpm to 129bhp @ 6,160 rpm.
I'm quite pleased with the figure, seems to pull well, just geared wrong (can't even out-accelerate some poor cars, but will march onto 120mph in fourth gear) so i'm picking up a different box soon.
Graphs to follow. Opinions? :)
  • Replies 42
  • Views 3.7k
Ahhh also, i want to smash the 130bhp mark, so i'm going for flywheel and anything you guys can recommend to squeeze every last drop out, like plugs and leads etc.
well done dude! impressive stuff, what box where you thinking? GT box's bolt on dont they?
Or an ATV g40 box would probably be better suited.
Personaly i would have taken a whole day trip around the UK to pass the miles :D
Nice,does seem to be a bit of a pattern going on with bike carb'd engines,because Sander_Beer managed about 138bhp with a sorted cammed AEE.
Stock AEE are iro 115bhp, with 125-130 from stock AFH. The latter being less torquey but more peak power.
Shame i didn't dyno my 1.6 AFH, i suppose it was about 140bhp with stock cams,i'll probably measure the AVY I've now put in,but running a cat i dont expect it to be as swift.
Sounds like you have very long gearing,and i can understand you going shorter,but id advise against going as short as a GT box. Over 6k rpm is rather alot for the AEE bottom end.
Fly wheel and leads/plugs wont make any difference to your performance I'm afraid, it's all lies!!
What mods have you got?
Haha Durham and back with the tracking out was enough for me thanks :)
Decided to go with an EQW to replace the EQY. The final drive will go from approx 3.59:1 to 4.1:1 i think...and the EQW uses the GT ratios too.
Going to team the gearbox with a lightened flywheel, may get the car in for another power run after this :)
Yes i thought it was a shame that some of your cars haven't been dyno'd either, its just nice to know for piece of mind i suppose.
Annoying really because my engine seems to get real power around the 7,000 rpm mark, which for some reason the power graph doesn't show. You wouldn't recommend revving this hard then? I have started to put better cooling into place, an oil cooler for starters and a bigger ally rad for later.
Mmmmm maybe not on this car then, but lighter flywheels normally have slight proven power gains, usually sacrificing torque.
I imagine the plugs/leads wouldn't be noticeable though.
Too much to list in full but carbs, cam and a much improved exhaust is about the crooks of it.
AEE = 75bhp, 100lb/ft
AFH = 100bhp, 94lb/ft
55bhp increase from bike carbs and a few mods is doing well I'd say....
i'm pretty sure he means those are the sort of figures they make as stock lumps with bike carbs fitted andy?
Ah, makes more sense now!
I'm pleased mate tbh :)
That's a great figure! How much torque is it producing?
As said above, It's probably not great that it's not making a lot of power till higher in the rev range due to the nature of the engine.
Although, a lot of people talk about the weak rods in the AEE, but I've never seen a case of somebody snapping rods in them.
Think I may go for an AEE next, I'm determined to be strong and stay 8v.
Do it max, don't be a pussy and take the easy way out.... (16v) :lol:
Need to get hold of one first lol
Plugs and leads will make no difference, not a 'not noticable' difference. Spark is a spark. The only differece is on insulation etc, and their ability to not heat up (plugs) thus reducing the chance of pre-ignition.
The only way i can see the power being altered for a lightened fly is that the reading is adjusted for reduced losses in transmission, but I cant see that being factored.
So either will be a waste, and potentially you may ruin the driveability. With the torque of the AEE, a lightened fly is likely to make idle and slow speed driving lumpy. Personally its not something I'd bother with on a road car, but its up to you.
If its cammed, has a good exhaust and your fuelling has been sorted, then air flow is your next port of call i would have said. Does it have a de-cat?
In the end though, it safe to assume you have made MASSIVE gains, and since I'm building a similar engine, I'm all for believing you figures! haha! My cam is only a GT though, but by the sounds of it, this may be more suitable. Although i have heard that the AEE cam is a similar profile to the GT. Will have to get the verniers out.
Not meaning to bag you man, you've done really well, I'll no doubt be tapping you up for advice at some point.
Silly bloomin graph doesn't give a stated 'number@rpm' figure for torque, but looking at the curve i would probably say it's about 125 lb/ft.
It really starts to get going at 6,500 after driving it i can feel this in the car, despite the fact the graph has clearly only been revved to just over 6k.
Totally agreed, wouldn't trade for a 16v anyday lol :)
Fair enough, well, driveability isn't really a worry considering this car will only come out on sundays for a play. I'm between dailys atm but will be getting another one soon so the polo comes off the road again.
Tbh even if it doesn't make massive gains/improvements i started out wanting to build a 6N a bit different from the usual 1.4 8v, with 16v bumpers, dished rims, sitting on the deck. I'm not knocking this, there's some cool ones around, but i think this is a bit different... and to build a spec list with things like lightened flywheel further spaces it from the rest, just my opinion though :)
Thanks guys.
original '96 AEE after 4000miles from brandnew:
Dynorun1_1997
and 4 months later with outlet manifold and exhaustsystem and k&n 57ki airflow and nothing else changed, the engine itself is still untouched:
Dynorum2_1997
That was 1997, 14years and 100000miles ago and the AEE runs still perfectly, absolutely.
Back in the 90s were so many people "chipping" their AEE's to get 90horses, mine has got that "power"*lol*just with letting the engine breathe in and out much better.
And just 4600revs for the highest power and that 150Nm in my eyes are good values.
Otherwise i would have bought a fucking 16V which btw here in germany is not that popular ;)
So M8 be proud of the AEE, in germanys 6N Poloscene it's more popular than the fucking and small*lol* 16V.
cheers
Christian
Edited by Christian6N
Dynorun1_1997
Dynorum2_1997
cheers
Christian
Fair play potty mouth, that's some good tech data there.
I loved the engine from standard tbh, loved how all the torque came dead early on in the rev range. Only problem was lack of power...
...but i'm happy with the results, it's never going to put out the kind of power a modified 16v does, i think the 6N2 GTi is in the region of 120bhp standard?
However, i do hope to give the everyday Saxo VTS a run for it's money... let's face it, they're the car everyone loves to hate, but that's the benchmark for me because i know how quick they are.
I really didn't like my AEE. Revved so slow, and when it did get going the power seemed to drop off so quickly.
A Cammed one on a good carb setup could be much more fun though, would be nice to feel the difference over a stock one.
I'll stick with fettling with 3F's for now though...
Totally understand what you mean, it was all spent by 4,000rpm or less in standard form...
...but as you said, cammed with rev limiter removed and it drives much similar to a 16v with the added perk of sounding like an 8 valve on carbs :)
Do it max, don't be a pussy and take the best way out.... (16v) :lol:
This is pretty good for a 8v in all fairness. Ull be keeping up with the 16v's
Such a sell out :roll:
You will come around eventually.
when you realise the money for bhp :lol:
