Smoothed 6N/6N2 Polo Bay's- Advice Required
Hi all,
I'm in the process of hiding the wiring in my bay and i'd like to know if anyone can answer the below:
1.) what wiring did you ditch? - i'll be getting rid of: side repeater wiring, charcoal canister wiring, GTI alarm wiring, passenger headlamp wiring (i use FK's so feed comes from drivers side)
2.) I'm thinking of taking out the engine bay loom and stripping off the cloth tape, then cutting a hole in the scuttle base near the ecu to feed through the wires for the wipers/ECU and brake reservoir level sensor plugs from inside the car on the passenger side.
as well as this i plan to then cut the loom going to the: horn, fuse box, driver headlamp, radiator temp/fan control and engine harness...i then need to extend the wiring so it goes through the chassis leg.
3.) how would you cut and hide this loom?
4.) anyone have decent photo's of smoothed bays? perhaps close ups of where wiring is hidden?
Thanks in advance...
  • Replies 9
  • Views 4.3k
iirc the wires are hidden in the chassis leg.
Most of the people that are doing a wire tuck are running carbs so they have alot less wiring.
Thanks for replying buddy...i guess its just a case of getting stuck in at the deep end then. 8-)
Photos of some 16v polo smoothed bays would be nice if anyone has any?? would like to see if they've hidden the engine harness too :-)
Running it on carbs makes a big difference to the wiring loom. so much can be lopped off. I've the wiring thinned out and running down the side of the chassis leg but over xmas i'll be running it down the chassis leg.
Here's a pic of how I did my bay:
Connor
I'm gonna mark up the loom today and mark the connectors i can cut off...then strip off the cloth tape and cut the loom back to remove the unwanted wires.
I've bought about 8 rolls of 25m cloth tape and a roll of heat resistant tape to extend the loom through the chassis leg and heat wrap it up so if i do decide to smooth the legs off at a later date i dont need to pull the wiring out again.
Any idea how much more the wiring needs to be extended for the chasis leg?? 2ft or 3ft?
I bet Mike would know... 8-)
There is no direct access to the chassis leg on the passenger side using a grommit inside the car- this is a myth.
The only suggestion i can come up with is to use a hole saw to make an incision directly behind the chassis leg from inside the car behind the heater matrix.
But i have no idea if this is the standard procedure- i'd hate to make a hole and find that its not hollow there for me to feed the wiring straight into the leg and have it protrude out of the bottom grommet further along.
i'll get some pix for you mate. you need to chop a hole through the bulkhead into the legs and i'll warn you now its double skinned so be careful.
finally!! the king of polo smooth bays arrives 8-)
thanks for the reply Mike, thought this was the case- where have you put your ECU? behind the dash?
I've ordered a set of Dart HSS hole saw's, with a bit of WD40 i should make my way through unless you suggest i use an Angle Grinder and carefully cut a sqaure out?
Looking forward to these pics! :-D
lol the king of polo smooth bays ha ha.
i have taken my ecu out, not having one coz it only controls the injectors nothing else inportant goes into the ecu so its a waste of space really.
a good hole cutter should do the job mate just be careful coz its double skinned like i said before and when i cut through and it hit the second skin it nearly ripped my arm off lol.
i'll charge my cam and get some shots of the holes i cut.
This is the mess i have right now...excuse the crap- the car has been sat for 6 months.
Thinking i'll do the following now:
Relocate the alarm siren to under the scuttle.
Relocate the ECU to behind the dash (sadly i need mine for CAN Gateways).
Extend the headlamp wiring, radiator temp sensor and fan wires + brake reservoir and header tank wiring.
Then run the main engine harness wiring UNDER the gearbox casing on the passenger side- what do you reckon? i could make the connections inside the car on the passenger side...then its just a case of tidying any engine harness wiring i have.
Already purchased some slim ballast HID's which i'll install inside each of my headlamps...
I'm not going smooth like you guys- the engine transplant is undecided at the mo and i dont fancy going to great lengths when i might swap the lump in a year. 8-)
