Autogauge boost gauge installation
Hi guys
My G40 came with an Autogauge boost gauge fitted but not wired up. It's one of the stepper motor ones, like this:
http://cgi.ebay.co.uk/AUTOGAUGE-2-52mm-Ste...#ht_6775wt_1135
I've wired in the loom from the sender today but have got some bits left over and no power :D Does anybody have one of these, or know where I could get a copy of the instructions?
I think the extra loom might be for wiring in more gauges, and the power/earth go to the two silver nuts?
  • Replies 9
  • Views 6.5k
Easy, just ask that seller for a copy of the wiring diagram, as you just brought the car with the gauge part installed but there were no instructions from the previous owner :lol:
Yeah I've asked them but I'm not hopeful of a response as I won't be buying anything from them :lol:
you put one of the wires on the battery positive, the other wire on your tongue and the vac feed down your japeye.
true story
saf: tried it, didn't work. got a buzz though ;)
Nige: Looks as though that's for the mechanical gauge. This one has got a sender in the engine bay. I've attached the vac line to it and run the loom through to the gauge itself. It's just power I need now.
I've got an Autogauge oil pressure gauge which has got the same connections but I can't find the instructions now :lol:
That's perfect, cheers mate :D I've been looking for the past week and couldn't find any instructions for that one.
Your not the only one, I googled the "autogauge boost gauge wiring" and there were so many people asking the same question, but most were for the analouge version
As an update, I finally got round to wiring it all up today. The wires are:
Black Wire - Earth
Red Wire - permanent +12v DC
Orange - dimmer +12v DC
White - ignition +12v DC
Hope this helps anybody else out there as there doesn't seem to be much info around :lol:
