4 point harness mouting points?
Hi all I'm gona be installing some 4 point harness's into my car can anyone please give me some advice on mounting points please
Can i buy the mounting plates and dril and weld them to my centre tunnel oppsite the factory seat belt mounting?
And can i use the original mounting for the rear seat belt clips and use 1 eye bolt thingy and double clip 2 harness straps together and be legal or do the harness's have to have each strap mounted seperatly
Cheers tom
  • Views 618
Use an eye bolt by the door where the exsisting belt bolts in, eye bolt on the seat where the seat belt clip is. Or get harnesses without clips and bolt them in using te old seat belt bolts.
As for the rear, rear bench seat belt mounts will do. But, if you're going for a four point I'd suggest bolting each strap to a different mounting point. Stops the harness pulling the mount in two different directions :)
