Replacing driversdoor glass in a 6n.
I did search and couldn't find anything about this.
I was in an accindent resulting in a broken driversdoor glass and now need to replace it.
Would appreciate of someone would have some tips and tricks on how to do it.
Or is it a straigt forward taredown and put back together thing?
Edited by Hebster52
  • Views 766
Nevermind... If there's any interest I'll post some pict while I do it today... :-)
First just unscrewed a couple of screws holding the doorpaddings located under the handle and the mirror lever.
Then just pulled the padding off.
After that I removed the speaker and the inside padding.
Loosened the bolts on the clamps holding the glass and removed the remaining glass splinters. Then just slip the new glass down with the regulators in the lowest position. The glass had to be slipped down nose first to get it in. Be sure to keep it in the groove when you drop it into the clamps. Then tighten the bolts int the clamps and it's done.
Easy to do :thumbsup: Only difference I did when replacing the mech was I removed the window when it was higher up, I undid the bolts on the clamps when it was level with the winder handle :) just makes it easier to get a good grip onto the glass.
Yes, well I did that also just winded the window down to show the clamps in the photo. :-)
Ahh fair does :thumbsup:
Atleast now I can whip my door cars on/off quickly due to the amount of times i've removed it :lol:
