Mclovins Mk2 Coupe S 1.6 16v Eaton Charged (in The Making)
Golf ABF throttle body is a direct fit to the gti manifold and has a tps already on it
There are two types
http://www.cheshirehouse.eclipse.co.uk/gti...ottlebody09.jpg
One on the left is a direct fit on on the right is the same style as g60
  • Replies 1.1k
  • Views 89.7k
  • If I decide to go in I'll be leaving a trail of bread crumbs so I should be safe
  • Looking a little sorry for itself now its finally been dragged out from the garage its been buried for over a year
  • Gonna shorten the rear axle by 4" and fit space savers, should get the sort of tuck I'm aiming for
i'm going with a G tb as these already have a valve to release to boost at idle, i'd find it easier to put a tps on a tb than to knock up some form of blow off valve. might be worth looking into the abf tps tho :thumbsup:
Why can't you just buy a BOV and fit it in the boost line Guy
Aye that would be easier?
What does it actually do that valve, literally open when the engines idling?
As the throttle butterfly closes that opens up and prevents the boost from blowing the butterfly into the inlet mani. I could use a dump valve in the boost line but I wouldn't feel comfortable doing so, if for some reason it fails its gonna cause some damage, I'd rather have a mechanical valve like this that is tried and tested, its a factory setup designed to work with a super charger so just seems logical. It's easy enough to retro fit a a TPS to one anyway
I'm not saying the bov route isn't a good one to take, just that I'd rather doing it this way as its what I feel more comfortable with :thumbsup:
Think i'll be using a re-circ valve instead anyway, don't like the noise of the dumpvalve.
Using a bit of 8V engine goodness is a good thing guy, can't go wrong with a bit of G!
Also, been thinking about using something like this for the set-up stage, as i want to slowly adjust the boost whilst getting the fueling and ignition correct,
http://www.ebay.co.uk/itm/MANUAL-BOOST-CON...02#ht_642wt_952
Or is something like this a load of shit? :lol:
Edited by MaxGT
That's for a turbo max :lol:
That can only increase boost from standard level as it bleeds off some of the pressure going to the actuator fooling it in to thinking there's less boost that there is. Works fine on turbo's (its what I tend to use on the denzels) bit useless on a supercharger
LMAO, i'm a massive idiot.
I didn't even read the text,
Could it not be situated in the plenum, and then bleed some pressure back to the intake? Thus controlling boost pressure?
In theory yes, in practice it just couldn't bleed anywhere near enough boost off to do that
Looks like you know what your doing dude, did you read a book about omex?
Next years action should be pretty scary...
8-)
Got the mounts yet guy? They got posted someday thats wasnt yesterday... bad memory...
nah not here yet mate :-(
okay bro let me know when you get them :thumbsup:
will do pal 8-)
finally got the boot lid prepped for paint
and thanks to kiz and his ETKA i now know i was running the wrong crank pulley. the AVY one is weighted and the AFH one isn't, this wouldn't of helped the issues i was having with the too light flywheel at all
weighted AVY crank pulley
the AFH style one can be seen here (photo curtasy of mikey :thumbsup: )
fair amount of difference between them
6n engine mount has arrived (cheers Matt 8-) ), had a little mock up and it looks like i'll have to take a slightly different route than I had imagined, but nothing drastic. The 6n rubber mount is fucking huge and would need extensive modding to the mount and inner wing so fuck that. I'm now going to use the mk2 rubber mount, i'll extend the mount bracket by about an inch to give clearance on the inner wing for the mount and then i'll knock up something to weld to the inner wing for the rubber mount to sit in. I'll probably strengthen it a little from under the inner wing too
Got a few pics but nothing of much interest
I think you should use the 6n mount tbh and build upto the right place using the bit of 6n chassis for that mount you have
it would save a lot of hassle with the charger mount And clear up that area abit
this will still mount in the same way as i intended but using the smaller mk2 rubber mount instead of the mahusive 6n one. the one in the pics is the mk2 one and it still needs the metal bridge bit lifting about an inch (you can see some of the washers i used to space it out for mocking up in the pics), and you can see how tight the bottom of the rubber mount is to the inner wing. the 6n rubber mount is like twice the height of that rubber
this will still free up the space in front of the engine, i'm just using a smaller rubber mount and instead of welding in the part of nicks 6n inner wing that the mount sits in i will be making my own much smaller and neater one because no matter how much chopping i did i couldn't get it to sit well and it just looked very out of place, the design i have in mind should be stronger anyway :thumbsup:
the con rods had some attention today too, the oil hole was drilled in the top of the bush and the last of the surface grinding was being done when i left :-)
Edited by Mclovin
Fucking forgot to re-bid on that eaton :crybaby: , so gutted!
So i take it your just gonna build a small box for that mount to mount onto, which will then be mounted on the wing?
Is it strong enough there?
yeah thats pretty much the plan, if it doesn't look strong enough i'll just reinforce it. the box will be seam welded and go from the top, round that rad and down the side of that part of the inner wing to spread out the load a bit
what did that charger go for?
I'll just leave these here
Glad you got them mate, sorry it took so long! I'm useless with posting shit. Get this on its way :)
if your just leaving the rods there i shall come and collect them ;p
are you going vw action this weekend Guy I'm unsure on whether to pop down or not
Nah I'm not going mate, pretty much writing off this year and hoping next will be better for actually getting to some shows :lol:
No worries mate 8-)
Them conrods look awesome dude,
Is the engine gonna have a make-over then? As i know you like them looking rugged etc
Hurry up and get the other mk2 sold so you can dump the funds into this one yeah ;)
