has any 1 on the forum used hammerite kurust
hello there got some rust and going to have ago of it myself jus really wanna get the rust gone does this work
Thanks Richie
  • Replies 13
  • Views 1.7k
rust does not go away unless the rusty metal is renewed, once rust is in the metal it will continue to re appear
so only fing i can do is cover it till it comes back
no cut it alll out weld a new peice in !! simples......
In answer to your original question...
Yes, I've have used kurust before and it's a very effective product. Normally two coats or maybe three are required. If it's in hard to reach places I have used a squirty bottle to get good coat and just leave it to soak in and dry.
As posted, cutting out rust is the ideal way, but this isn't always do-able and rather than leave it to get worse, this stops futher rust :)
Not in every case. Rust needs air/moisture/iron. Eliminate one of these things it won't. Kurust changes the iron/rust into an inert alloy, thus preventing more.
thanks for the helps guy so should i give it a go?
It's better than leaving it to rust more! :)
I hate the shit. My first paint job - I meticulously prepped and painted some arches, using Krust to 'kill the rust'. Rust came back within a couple of weeks. Shite bulldecrap. To be avoided IMO.
As stated above, new metal is the only sure-fire way.
I've just used this myself for the first time.
Il get back to you with any observations.
I used it on my door frame last November two coats and then when dry a coat of grey primer and I have'nt got around to topcoating it yet!! and no sign of any rust showing through the primer.
Your lucky then as primer is porous and will let the water/moisture through eventually. You may not be able to see it under the primer, but sure as eggs is eggs, it will be corroding, slowly but surely. As stated previously, best way is to cut out all old metal and replace with new, or in your case, rub the primer down again, check, re-primer then get a top coat on it.
fnx for the help and oldeboi let me no how it goes
