Weird clutch pedal
Heres one for you, one my mk3 polo the clutch pedal sits real close to the brake pedal, closer than it used too.
And i don't have a clue why, it still works properly there is nothing wrong with the clutch cable and from what i can see there is nothing wrong with the pedal itself.
As you can imagine it can be a pain in the arse when depressing the clutch it sometimes catches the brake pedal.
Anyone seen this before or have an idea what it may be?
Edited by maherjack
  • Views 1.3k
WTF?! Seriously, that is the strangest pedal setup i've ever seen :lol:
Have you had a look at where the pedal hinges? Seems to me like part of it has cracked/broken and it is only a matter of time before the whole pedal breaks off :(
i had this on my old GT but with the throttle pedal, have a gander up on the hindges dude you might be able to salvage the bracket! :)
Yep that is bent!
Yep that is bent!
The whole car is being bent atm. It is a weird one because i cannot see whats wrong to make it do that.
How hard is it to change a pedal box in a mk3 polo?
Edited by maherjack
I don't think its too hard... its just a bit fiddly due to where it is :)
