filler/fibre glass
I've plastic welded my valver front bumper, I'm at the stage now where i need to apply filler and or fibre glass what would you recommend guys ?
  • Views 744
Fibre glass over the welded area for strength, gins it back so it's smooth then put a couple of skims of filler over the top just to finish it off and shape a filler is easier to flat back and shape ;)
id use bumper fillter over the plastic weld. then on the back id fibreglass for strength. as fibreglass cracks and will show up if u apply to the front
Fibreglass won't just crack, hence using it "for strength"
cheers guys :p
