Mk2 breadvan woe's! :(
Sup chaps...
My bready has just been through its MOT with a 80/90 drop kit on it thats just been added (too the springs legs off of my mk3 which was runnin 15's with no problems) ..
Problem is, it passed its MOT but it is rubbing like a BITCH on the front end! anyone else have this problem? I'm running P-slots (14's) with low profile tyre, so i cant see why its a problem!
I could put some steelies back on but thats just poor IMO.. or i could sort the suspention a little higher, but again, not a fan of that idea either!
Anyone got a mk2 bready at a similer drop? with a similer problem? Any pics or anything? Someone cheer me up coz its pissing me off! It must be do'able!
  • Views 1.4k
have you rolled the arches?? and on mine I'm running 60/80 drop and dont seem to have any problems (but i am wanting to go lower) you could get some 13's and use them instead?
were's it rubbing? on the arch? get 13's drop it lower to the ground :) or could strech some new rubber on
put some 165/55s on the p-slots fitted to the rears. anything over 165 wide is almost always gonna scrub on std breadie arches
Does it catch underneath at all? IE exhaust, sump?
Just the front arches?
Mine used to rub on the drivers side front arch with 185/60/14s and standard ride height.
Edited by oldeboi
Breadvans just can't carry off being ultra low like coupe's and saloon's. Give it some justice and raise it a tad.
thats what ie done I'm afriad! Standard sucks balls tho, the rear at standard aint so bad, its just the front. i can litteraly make a fist and put it in the gap without it touching the wheel or the arch! :(
need narrower tyres.. or wheels. mines running a 70mm (ish) drop all round..
had 14x5.5J wheels on when i got it n had scrubbage issues soon as it was dropped.
now running 13x4.5J steels in the winter and 13x5.5J's allys in the summer... slight stretch on the tyres... only get very minor scrubbage on the front when i hit a big pothole.
