whdst to look for on mk2
I'm on way to have a look at a mk2 1985 polo coupe and just wondering if anyone had any advise what to look out for
  • Views 913
Rust! Floorpan, battery tray, corners of windscreen, in the boot, Everywhere really :lol:
If the body checks out okay then just check all the usual stuff, any leaks or damp, check everythings working, check for good gear selection, clutch bite etc etc.
Is there anything that they are really prone too
Fuel tank necks mainly.
Rust, don't forget to check for rust in the arches too, and also have a look at the inside of the drivers side rear door card - there is a metal pipe there that holds a breather for the petrol tank, and it collects water and rusts... usually first you know about it, its rather serious (just have a look at Max Crox's mk2 in the gallery, he has just replace the rear quater panel!!!)
Oh and rust on the fuel filler neck, although not terminal, and new tank is only £50-£60 it can be a pain, to replace but possible in a few hours
Poo berg carbs....
