sanding headlights
hi was wondeing what sandpaper to use we sanding the lense of the headlight mine all are yellow and rough cheers
  • Views 1.3k
don't you have plastic lenses on the mk5 6N2??
yea plastic lenses,, its a mk4 6n,, my usernames mucked u lol,, would 600 sandpaer do?
Megs do a plastic lens polish, surely much better than taking some sand paper to it.
I've used a car polishing buff before and it done the job
600 is too aggresive
i have done these with 2 sets of 6n2 xenons, go over them lightly with 1500 wet and dry and polish up with your preferred cutting compound then use a finer cutting polish then finally a wax for a good shine
cheers for the advice
I used a rotary and some 3M fast cut and worked it in, then hit them with some final finish from Menz they are now crystal clear.
