how to remove a dent?
i have a dent which is off medium size and is near the door, was wandering on how i could get it out?
  • Replies 10
  • Views 1.4k
picture might help matey.
Dont get it out FILL IT :-D
or if your good with panal beating tools buy some
it its really that bad replace the door or panal
pics would help which is best to suit :thumbsup:
call your local mobile dent man
pay him 50 quid.
big f***ing hammer :unibrow:
hahaaahhaa yup!
bang it out aabit from the inside and fill it :D
Use An Electromagnetic Slide Hammer.
Attach to dent.
Use little force a little bit at a time untill the dent is out.
You may need to use a bit of filler and paint afterwards.
Or use a standard slide hammer which means drilling a hole in the dent and then defo using filler.
use a glass sucker to get the dint out I've gotta do it to my 6n :)
do glass suckers actually work?
I have a cooler method. Heat it up for ages with a hair dryer, then quickly spray it with that 'air in a can' used for cleaning pc's. If you hold the can upside-down you get liquid CO2 out and the sudden change in temperature causes the dent to jump right out.
Check out youtube and you might find a vid
If you can get to it on the other side then hit it out with a hammer, use soft hits so you don't stretch the metal and make is weak. Could help using a block of wood and then hitting that with the hammer. When using filler to get best long term result try using as little as possible 2-3mm max since the more you use the more chance of air getting trapped in the filler and after the paint and it looking nice with in 6 months the paint will be cracking because the air which was trapped inside has come out the filler. Hope this helps
