Clearout
Would like that turbo off you, but haven't got the pennies atm. Whats your lowest price on it? Any pictures?
  • Replies 30
  • Views 2k
I've finally set upon a project which I'm really wanting to finish, as a result i think I'm due a clearout of all my parts
K+N Weber dmtl/dmtr plenum, rotates 360, slim line design to fit a remote air filter, polished finish, needs a buff - £60posted
New professionally refurbished GT/G40 distributor, new hall sender, arm and cap - £45posted
GT inlet manifold, Good upgrade for the G40, pretty clean - £45posted
G40/NZ inlet manifold, more torque for your gt, very clean off a low mileage car - £25posted
Volkswagen motorsport twin weber inlet manifold, fits small block vw, used and painted grey, overall casting is in very good condition - £125posted
MPI injector covers/jackets, VGC complete with foam inserts - £15posted
GK soild lifter head camshaft, highest lift available for the early heads, used in goog condition - £SOLD
Helix 200mm organic clutch friction plate, done around 400miles, loads of meat left on it, along with a new genuine vw g40 pressure plate - £100posted
Phil J T25 turbo manifold, log style made from thick mild steel, very good condition - £150posted
Garrett T25 turbo to suit the above manifold, good condition, no play in the shaft, will need clocking to fit the polo - £80posted
Bike carb setup, half complete, laser cut flange with runners, need welding togeather, zzr600 carbs in good condition with suitable rubbers - £80posted
prices are a rough estimate and I'm open to offers on all of the above,
more to come
thanks
will
Yo, can you reply to my pm please :)
As above pm with u mate
bump
ooooh is the pressure plate uprated or standard g40 unit? Can you get a picture of the clutch mate?
Any pictures of the rocker cover?
