6n2 clocks into 6n
hi dubbers i want blue dials with red needles in my 6n polo like the 6n2 how is this done HELP HELP HELP
  • Replies 20
  • Views 4.8k
you'll notice the 6n2 has 2 circular dials whereas the 6n has one instrument cluster.
yeh but i was looking at the oval shape of both clocks and they look both the same apart from 6n2 is two circle clocks and 6n is just a complete unit but I'm sure it could wrk ?
I wanted 6n2 dials in my 6n, I did it :) and i'm happy with the results, here's a picture showing about 10% of the work involved.
WOW! looks like alot of work mate so do these 6n2 clocks plug to the original 6n wiring and do they fit in the 6n dash with no modding ?
pmsl no hes completely rewired his car as he uses stand alone management with 6n2 wiring and fitted a 6n2 dash
6n2 dials do not fit the 6n dash!!!!!!!!!!!!!!!!
but there practicly the same shape/size so why wont they fit 6n dash i really dont want the 6n2 dash :(
The 6n2 electronics are completely different to the 6n system, the use a can bus system to control the interface between the car and the clocks. Other things such as windows etc are different also as they run through a comfort module controller.
In short, it requires a dash conversion, alot of time, effort and patience.
You'd be better off converting the LED's in your existing clocks if you're after an easy life.
AAAAAAAAARRRRRRRRRGGGGGGGGGGGGHHHHHHHHHHHH
there not even similar lol =D if youve got the late spec 6n dials then you can change the LEDS on them so that they are blue and red anyways
ok guys calm down I'm new to these vw polo's so am learning here lol i have a 99 (v) reg polo 16v i took the clocks out today to find that it has 1 bulb for the main beem lights and the rest of the clocks have these white circle things that the needles are attached to does'nt look like you can change erm ;(
a V reg should be led not backlit lights, i know carl (po_low) did his, post up a pic of your clocks and well soon tell you =D
I'm only getting stressed cause I'm a moody c*nt lol =D
yeh my clocks have these lil sqaure leds soldered to the board and the only bulb (twist n lock) type is for the main beem. it just seems to me that its alot of work to get these clocks to what i want :cry:
yeh its a lot of work but well worth it!!!! =D
ok guys thanx for your help gonna have to think hard bout what route to take 8-)
or buy 6n gti ones, which have the red/blue lighting in them ;)
didnt know there was a 6n gti only thought there was a 6n2 gti ??????
would these clocks fit and work from the original loom http://cgi.ebay.co.uk/VW-POLO-1-4-TDI-2003...c#ht_1699wt_754
no, they're 9n clocks, you've got no chance.
i fitted mk4 golf clocks into mines looks sweeet! you should try they fit with a little bit of adjustment
first of the 6n2 clocks shape can be made to fit, just fabricate your own little plastic piece its not hard and also ok 6n2 clocks need the wiring for them to work but…..the clocks form a 1.0L lupo before the year 2000 or 2001 i cant remember exactly will plug in and work right away with no modifications to the wiring
Zander m , you got any pics of your dash? Sounds good.
Jordan, so early lupo clocks would drop into my late 97 6n?:)
Mark
