6n2 GTI
Got my new GTI a few days ago.. already had the rear wheel bearing replaced and tracking done, needs the front passenger doing including both ball joints. Also.. when pulling off sometimes i will get this loud clunk/bang thought it may of been the exhaust.. it was raised as it was a little low couple days ago and started again tonight. Also once hitting around 4k revs.. power seems to stop picking up.. OH and.. my front light washers will come on instead of the window washers and the rear wiper randomly comes on and doesnt seem to like to stop :S same with the front wiper until flicking the switch up then down again (even though they will come on without touching them) It was a good buy but its quickly turning into a project car with these things keep cropping up :(
Any advice would be appreciated (i know this should probably be in tech but i want to show it off also so members neither tech were appropriate)
Heres the new ride anyhow, need to take a few more piccies after a good wash and polish :) In great condition though, needs a lil touch up on the splitter and a new passenger mirror as seems to be bodged with electric tape :?
Edited by Marru
  • Views 1.3k
Clunking, will probably be the balljoints if you say they need doing?
Wipers etc, I'm going on you haven't figured out polo wiper controls :lol: They seem to confuse everyone.
Noo because i will just be driving and all of a sudden the rear one will start wiping away for no reason then the front usually follows suit :?
rear wiper's a common fault. Never experienced it but I've herd it can drive you nuts. Think its the button on the stalk...new stalk would solve it along with your other wiper problem
Clunking could be exhaust, or a CV joint. Even a engine mount.
Front washers, theres 2 motors so could be fuse or motor to the main washers.
4k it should pull the most really. Could be a sensor down. Try get it on vagcom to see if it shows up any faults.
There little niggles that can all be sorted in a weekends work!
Thanks! :D I shall note all these down and get them checked out ^_^
This probably won't apply to you as you have a gti and they have the extra bit on the end of the wiper stalk for the rear wiper but it just might work, just push the wiper stalk away from you and that should start/stop the rear wiper? :)
rear wiper... better off removing it and blanking it, looks much better (i have done it on my GTi)
Clunking noise either CV joint, suspension top mounts or probably the ball joints if they need doing.
And the 4k revs mine had same problem and wouldnt go over 90mph it will be the air flow sensor which i got second hand for £25 and fitted in ten mins which cured the problem!
Well i have found out why my car "knocks" had a rather nice large bolt missing out my suspension (the main bit in the middle of the car under the body) the wheel bearings are fine as well as the ball joints. So the car is getting that done, had to leave it at the garage >_< also found out i had two wheel bolts missing off two wheels -.- seems my car likes to eat bolts :lol:
