Near new rear drum full set up mk1-3
Hey just converting my mk2 bready to rear disc and so am going to sell my rear drum full set up its near new only done about 300-400 miles.
Includes
newish drums
newish pads
newish spring kit
newish wheel bearings
newish slave cylinders
these were all bought at the same time and fitted all together the rear brakes were fully overhauled by myself.
rear plate and stub axle so literally everything you need to just take your old ones off and put these straight on with no hassle setting up the pads and springs i will send them basically fully assembled. once you put them on you will just have to bleed the brake and hey presto near enough new full rear brakes.
drums are hammerited red to look better and prevent them rusting.
will throw in a rear mk2 handbrake cable if its wanted
I'm looking for 50 collected from corby nn18
or 57 posted as they will be quite heavy.
200023_1957784504961_1253192899_32235399
wheel bolts not included
please pm me
thanks
Peter
p.s. il get pics up later
Edited by StinkyPete
  • Views 208
wow so its a handbrake that will actualy lock up! haha mine is shocking, i may have to buy this lot :)
yep my handbrake worked amazing lol
let me know if you want it
ebay link
on this basis... maybe you should do cheaper :-D
ebay link
hmm his does come with slave cylinders though
and mine includes the backing plates also with all the springs and pads fully fitted in place to save you the time its literally bolt this on put drums on tighten up stub axle nut, connect slave cylinder to flexi. then just put your wheel back on and your done and I'm pretty sure the back plates are worth quite a bit and also like bilco said this includes slave cylinders too.
bump pics
all older polos are the same arnt they? including GT?
If so I've sent you a pm :D
Cheers, Liam
