Ouchh!
So tonight me and some of my friends in there nice modern cars with plenty of ground clearance drove to Matlock and I ended up following up a very tight and VERY uneven road where I experienced my first real bottom out, which was rather unpleasant to say the least. I believe I actually got stuck at one point and then just had to press one and scrape my way all the way to the end. It was definitely my worst driving experience to hear my first car being ground away from underneath me.
Anywho just a few questions as a result of this:
I can see the bit that is scraping and its dead in the center just behind my front wheels, it almost looks like some sort of plate holding up my exhaust but until Tomorrow when I get it up I can't tell. Just wondering if anyone knows what it might be? Hopefully not something to important :(
Secondly I was told Holly (91 GT Coupe) is running 80mm drop but we think its 80-60, its on the standard wheels (13's) and I'm looking into getting 14's and new suspension set up for ground clearance and looks. What suspension set up are you guys with mk3's running? With 13's and 14's etc.
Once again sorry for the n00bishness, thankyou.
  • Replies 25
  • Views 2.4k
Its some sort of brace bar thing below where the cat is/would be
nothing important, mines battered to fuck.
Its coming out when i fit the subframe, as its the lowest part of the car and serves no purpose really
Think its there to support the exhaust a bit if it comes loose.
Wouldn't worry about just 1 scrape dude, these old mk3's will take a lot of abuse!
I think I know what you're talking about, it's like a brace held on with 4 bolts, just behind the cat. A little bit of scraping on that will be fine.
My old car used to scrape and bang the road so bad i had to take that off..... so then it just obliterated the cat. Ah the joys of being low...not a good idea :retard:
wore the bolts down on mine till it started rattling so pulled it off. with a subframe fitted its surplus to requirements anyway.
What size wheels and what suspension set up are you guys using?
Mines lowered the same as yours, on 13" GT steels with 165/65 tyres and it scrapes a lot. No real damage though. I've hit that crossmember hard numerous times getting off of the grass infront of my house and it's holding up ok.
You'll have one of these at some point
Thats something to look forward to haha. Put some socks on man hhaaha
what the fuck happened to that? haha
Thats rough, musta been hanging pretty low? I tucked mine right up.
Mines on a 80/60 kit, with lowering topcaps. so about 90 up front.
On 13" RA's with 175/60 tyres.
24238_10150145606610154_818965153_121435
oh and the white one next to it is Jons (Iscariot)
Whos was just stupidly low :lol:
(2 Grown men + 2 crates of lager + 4 sierra diffs + 4 driveshafts + 4 springs + 2 front shocks + 8 wheels & tyres) x 450 miles =
Matt
I also had to hammer to rear arch lips back and the tub out a bit in one of our many service stops as the tyres were catching.
Found another - this was the final time that the exhaust fell of the mounts. It then completely removed itself from the car. Check out my super spafe jacking methods. Just like the haynes says, jack up with widowmaker and support on a ally cat superlite slotmag and the spare wheel.
Edited by stealthstylz
I only have problems with my middle box scrapping on everything does anyone elses?
Yeah i did, on speedbumps and the like.
either do away with it or get a smaller one. standard ones are pretty big and catch due to the angle at either end.
i figured that if i kept on smacking it onto the floor it would eventually wear away and i wouldnt have to worry about it any more :lol:
Haha yer I tried this and it smacked my zorst all the way off the car so had to higher it in the end. Is there much of a tone changed just removing the middle box and leaving the rest standard?
Robdavies did it with his and it sounded pretty good, had a nice little burble to it, sounded a little bit raspy as well.
Ahhh cheers dude :D
old mk3's take alot of abuse... unless its a loon. I went over a speed bump when i was camping and as my front wheels went over it my exhaust manifold studs snapped leaving me with a useless piece of tube going along the bottom of my can that used to be an exhaust. also split the petrol tank at the filler neck , id just had this replaced for the same reason.
i would like to add that all passengers and luggage was made to get out of the car becasue the speed bump looked particularly scary
Just done this to my girlfriends Polo. I cut a few inches after the flexi and slotted the new pipe inside it, then it just slots into the rear section.
1m of stainless 38mm diameter pipe - £17 off eBay
2 Ubolts (42mm and 45mm, I think.) - £2
Exhaust fitting paste - £3
Cheap fix and has solved all the scraping problems. And has made no difference to the sound.
Win.
looking at yours on your wheels toby, i would say mine is lower!
MK1's look different tho. But tbf it doesn't look that low there.
i was told that the brace your catching helps with the rigidness of the car.
I do not understand why people drive with GT's so low. I've done it and it was the a complete waste of time and money.
once you stick a straight through on it rarely catches, only thing that scrapes now is the u clamp on the pipe as it goes under the axle.
will get a pick of the current one. 8 months and still going :)
Edited by Cymro
Mate I agree with you, its the way I bought it and it will be sitting and a steady 60-40 soon.
I would have thought the "brace" was there to protect the cat or something, I can't imagine it having much effect on chassis stiffness. I've never refitted the one on my car.
