Triple square or Torx
I'm just trying to adjust the boot catch but noticed the bolts aren't actually torx - I've been told they are triple square (common on german cars?) - can you use torx bits on the triple square heads - if not does anyone know a good supplier
thanks
  • Views 908
The parts lists them as "polygon socket head" I brought a set of security bits from my local market £10 and it includes several square bits
I've discovered that triple square is an americanism - they are called XZN or splines so I've bought a Draper set off good old Amazon
cheers
