Halfrauds ready mixed paint.
Just wondering if anyone has used the ready mixed spray cans from Halfords? If so, are they any good? i.e Are they even the right colour?
I have a Dragon green 6n (LC6P) and managed to pull off a whole load of paint when taking the bump-strip off of my passenger side door, at the time I just painted over with some gloss black that I had lying around to prevent it from rusting, but i'm getting more and more annoyed with how it looks.
Was in Halfords looking for solutions the other night, and I saw a ready mixed 'Dragon green', but there is no paint code on the can. Will it be the right colour?
Any help would me much appreciated, Thanks.
  • Views 799
It wont allow for fading of original paint but the colours are a close enough match in some cases.
Its not going to be a perfect match, they very rarely are, the issue being is that its been out in the sun for over 10 yrs and the paint will have faded somewhat, there will also probably be a suffix to your paint code for different batches of the original paint which would have all been slightly different.
If you want to do the job properly get the paint mixed, preferrably not by halfords, i used to work there and the system they use is shit! their paint will be pretty close, so if you aint bothered about it being perfect then go for it, but for how much hassle extra it would be, id go to a proper paint shop and get them to mix a colour up for you, it'll only piss you off in the long run if its not done right.
I sprayed a number of panels on my old car with halfrauds alpine white and the match was very good. Better than when I got a couple of cans 'professionally' mixed up.
At the end of the day dragon green is gonna be much harder to match... but there's no harm in trying, if i were you i'd go in get a can and see what it's like, they're only what 6 quid or something?
Make sure you prep it well, and use the correct colour primer too. Can have a massive effect on the overall finish.
Thanks, guys. Yeah, they're just over £6 for a 300ml can, which should be more than enough paint. The area that i'm wanting to cover is also quite small, only about a 2x25cm rectangle anyway, so even if it's not perfect, it shouldn't be too obvious.
Thanks for your help, think i'll go get a can this weekend, weather permitting!
