1.1 compression ratio
Okay, gk cam is on the way, to go on a 1.1 formel e so it's higher compression than a standard on already, is it possible to increase it using a thinner head gasket and would there be any gains? Presume there would as the gk had a higher ratio?
  • Views 474
You won't gain enough from the extra compression to justify doing it.
