Mk2 coupe breaking
Any interest in spares from a 1990 Mk2 1043cc Polo Parade Coupe?
Has 120k on the clock.
Good engine with nicely running pierburg 1b3 carb
5 speed gearbox.
Parcel shelf with 5x9 cutouts.
Twin headlights but only one pair any good.
Recent replacement fuel tank and rear springs.
Offside and front body panels are not so good.
Seats tatty.
Located in near Warwick.
Could post small items.
  • Replies 35
  • Views 1.9k
Gear box mount?
pics and price of the twin headlight and grill
also what do you mean when you say only one pair any good which two??
thanks
matt
Gear box mount?
The upper front one, or lower rear?
thanks
matt
The grill is broken as are the offside 2 lights.
The nearside 2 are OK and I think they are the same both sides.
So there is one high beam light and one dipped beam light available.
PM'd
Gear box mount?
Upper front i belive :)
Gear box mount?
Is it this one with the bolt head on the middle of it?
If so do you want the whole lot or just the rubbery bit.
£5 sound OK? plus post, unless you want to collect it
ta for the boot clive was nice meeting you :)
how much for the fuel sender unit if its working??
cheers matt
cheers matt
Fuel sender is OK.
£5 plus post, or you can collect.
Clive
Do u have the arch kit
What is the colour of the car?
The black plastic trims round the wheel arches?
Three are OK but front drivers side is a but mangled.
Its in one piece but a little scuffed and a small split but that is under the arch so you probably wouldnt notice when fitted.
Its Blue code LA5B. - Marine blue i think.
I have got a picture of it now so I will post that.
Here is a picture of the car.
I drove it for four years and it was brilliant.
I know how hard it is to get parts sometimes so I really want to help keep other cars on the road.
So if you are after any bits and bobs, or something more major, just let me know.
The hatchback has now gone, along with the switches from the dash and the centre console on the floor by the gearstick.
I will have to sent it to the scrappy soon.
what condition is the boot lid in? Any dents/rust anywhere?
Boot lid has gone now
hey dude, i need a cut out, of the slam panel of the mk2, it can be seen in the following pic as the black bolt on section
please pm me if you can cut it out for me? more metal is better, i can cut down to size
You have PM
Winow Mech and Window holder?
Which side- or both.
£7.50 each or £13 for two plus post, or you can collect
Do you still have the alternator I'm in need! cheers
You still braking this mate in need of the bracket that connects the rear axle to the underbody of the car cheers
There are 2 brackets, one each side at the front of the axle.
£7 each plus post if I can get them off.
Which side do you want
Clive
