1.8T ECU Wiring/Pinout Diagram?
Anyone know how I could get hold of a wiring diagram for a 1.8t ECU?
I was thinking maybe a Haynes manual, but the only one out is upto 2005 pre-facelift
Is there anything else along the same lines as a Haynes manual?
  • Views 5.1k
Elsawin 3.7 would have all of this, (try eBay) I'll try and have a look for you later today if I get a chance
Failing that it might be worth trying a Golf Haynes manual, although this is making the assumption that the ECU will be the same on both!
Edited by AMD_Man
This is for the ARZ 1.8 turbo if you have the code for your engine I'll scan the diagrams
Mate that would be absoloutly amazing!
Its the 1.8T in a Polo GTi 9N3
I think the engine code is BJX - Not 100% sure, that's the only 3 digit code on the engine bay label (On same sticker as serial number)
Cheers! :-)
Cheers! :-)
OK found your engine code, can you PM me with your email as there are 12 pages of diagrams so it would be too big to post on here
Nigel
PM'ed mate thank you!
