removal of aerial - mk3 polo
gunna buy a new aerial as mine has snapped. can unscrew the top of it then do you have to partial un bolt the wing to remova the old aerial?
  • Views 823
Undo cable,and pull it through the grommet by the fuse box.
Remove a couple of the bolts for the plastic arch liner,just inside the arch,so you can get your hand in there reasonably comfortably.
Pull up the aerial a few inches so you dont loose it in the wing. Undo the aerial's collar. You may need your left hand to hold the aerial up in its hole.
Then with your right hand in behind the liner, push down the bracket holding the aerial - you dont need to undo it,just push it down and it'll slip off the end of the aerial body.
Now withdraw the aerial with your right hand,through the liner. The cable will follow through,but its best to get a finger round it where it meets the aerial body,to ensure it doesn't get damaged as it pulls.
ok cheers ill give that a go!
