Bonnet gas strut
I just made myself a bonnet stay out of a boot strut from a nissan micra K10. A mk3 fiesta boot strut would be far better.
I used this one cos it's all I had laying around. First I chopped off one of the mounts cos it was unsuitable, I then removed a bolt from the bonnet hinge, attached the remaining mount with a longer bolt, drilled the other hole through the bonnet and bolted that on, then drilled into the inside of the wing, a loose-ish bolt with a nyloc on the end allows it to pivot.
Ok that was an awful explanation, I'll let the pictures do the talking.
  • Views 1.2k
tbh a proper lifter like this would be far better, the ones i got from ebay - if i used 2 the bonnet is like a catapult and 1 hasnt got enough power to even lift it!
I feel for you dude,you really have done it the hard way.
But at least you didn't mug yourself of cash you didn't need to spend.
See,i used the ones from the tailgate of a Saxo. The ball fittings both ends screw into the Polo MK2 in place of nuts that were there previously (though one end needs an M6 nut because the hole it uses is for a self-tapping coach bolt).
Took literally two minutes to fit,though i did spend another three minutes measuring various struts in breakers.. They're the right length,and they look OEM fitted.
I first only used one,it was strong enough,but made the bonnet flex a lot when it was open. Two certainly make it better.
Hahaa I've always wondered what those eBay jobbies are like, obviously not worth it then :lol:
Those saxo struts look sweet mikey, do you reckon they'd be as easy to fit on a mk3, I don't know how different it is under the bonnet to your mk2 but can't be much change surely?
I would do it the proper way, however I have more important things to spend my cash on right now, like sorting out the steering, the tracking is out by 14 degrees atm and I can't sort it til I get a new track rod end. I had the parts lying around so did what works.
Edited by hammerong
^^ This is the 'proper' way, if problems people have had with ebay kits are anything to go by. It fits as if it was engineered to do so.
I'm sure it'd fit a facelift model the same,that sheet of the inner wings are the same pressing - i cant see them moving the hole for a coach bolt when they didn't even change the flange where it welded to the older design front panel.
When I say the proper way I mean using a strut with ball joints on it like you've done. I can always upgrade in future.
The strut I've used has rivets with loads of play holding it onto the bracket to allow for the slight twist. It may not be perfect but it works.
Ah yeah,that hindered me with the tailgate. I think there's enough metal in the C-pillar to tap a thread for a ball joint,so i can fit stronger struts there too. Well,in the nearside,doesn't look like they put a plate in the recess on the offside.
But that's another story. For the bonnet at least,the screw-in ball joints are unbeatable.
I've looked into a scissor mechanism,like some modern cars have on bonnets and saloon boots,to replace the bonnet arms. This'd allow higher bonnet opening and make room for a bigger battery. But I've not yet found one that'll work easily and look OEM.
