Handling in the wet...
Ok so I've owned a mk4 polo for about a week and half now and loving it, yes its not the same as a mk4 golf but mehh another subject. Anyhow does anyone else feel a bit skittish in the wet with their polo as mine when going round a round about and turning sharpish the front end will slip obviously but then the rear end gets out of shape aswell, is this normal for a polo?
And no i dont drive like a twa* i was just wondering if this happens to all of them when in the wet, it maybe a case of the tyres not being a good make, they have alot of tread so thats not the problem, another problem maybe we fu** the handling on these cars as we slam em haha.
Just a observation.
James
  • Replies 11
  • Views 1.3k
Just a observation.
James
Front end going out is understeer, rear end going out is oversteer, front of my MK3 will understeer on wet roundabouts if pushed but not had it oversteer, only dropped 40mm though, has cheap tyres on winter steels, handles better on the wide alloys with Continentals.
You are right about slamming them, a lot of lowering can knock the steering and suspension geometry out quite a bit, a start may be to get the car laser tracked ?
Edited by MarkGenesis
The Mk4 does like a bit of lift-off oversteer if pushed into a tight corner, they have no weight as such on the rear as they are so if you corner hard and lift-off (taking more weight off the rear) they will try and swap ends on you.
Slamming them can fuck the handling if you just deck them a leave it, but take a bit of time to set it up and they can become a weapon in the bends, even having a tendency to pick up a rear wheel at times.
what profile tyre you have?
i had to swap to lower profiles with my current wheels as they would roll in the dry,and skip in the wet
when i first bolted the current wheels + tyres on i knew from the first corner they wasnt right
I found on my 6n that the handling was fucking terrible as standard, then dropped it on coilovers and it made a world of difference on a smooth dry surface, but as soon as it got slightly wet or bumpy it just understeered especially when turning hard.
My ibiza GTi was the same, but add a bit of torque into the equation and it just made it worse, the addition of a front strut brace stiffened the front up a bit and made it oversteer a lot, however the Ibiza GTi's are notorious for over steer with the narrow rear axle.
They were both on cheapish tyres, stretched nankangs on the polo, and mismatched 195/50's on the beeza. My new car is a MK2 golf, on Continental contisports, lowered on fairly decent coilovers with a strut brace and the handling is just amazing compared. Shows what a better set of coilovers and tyres can do for the handling.
I'm not sure what tyres are on mine but they dont look anything spesh. Tracking on it wouldnt be a bad idea but I'm not going to fuss around with that till i get the stance and wheels i want. I'm glad other people have these problems and not just me.
James!
i am perfecting the art of lift off oversteer it just makes the car more fun to drive but yeah alot of it is tyres. cheap ones are shit
I hate wet days, my mark 4 is horrible in them. But i'm just about to go and get new tyres on the front that are alot better then the cheap ones on now (and they are bald like slicks). So i hope wet driving is about to get better!
Mk3's are the same, standard steels with cheap tyres and hard suspension = sideways if you give it death (on a private road of course :ninja: )
My gt was awful in the wet. 4 wheel drifts round roundabouts were very very common :lol:
G40s are useless in the wet especially. My gt used to light the fronts up in 3rd at 30 on a roundabout in the wet and understeer at 10mph with some very expensive Faulkens on the front. I just dont think they have the weight there, it cant do them any favours. Road surfacing doesnt help either.
My breadvan thinks its a 200sx in the wet :D
tyres have a lot to do with it in my experience, i used to run Avons all the time, and had some terrible issues in the wet, but recently went to kumhos and they are so much better. THe KU31 Ecsta sport was reviewed in a few magazines and was their best "all round" tyre (even over Eagles and other much more expensive tyres)
