removing window winder from polo 6n2
Hi all
I'm going mad here. I have an old 6n2 2000 reg. I'm trying to replace the speakers but I cant get the door panel off. I cant for the life of me remove the window winders. I've trawled you tube and cant find anything that will help. If someone has a link to a video, that would be great.
Dave
  • Views 2k
ps. if you dont have a video link and but do know. please tell! lol
Removing window crank 10.99 ä
‒ → Release the locating lugs -arrows- on the trim plate -1- and swing the trim plate downwards.
‒ Remove screw -2-.
‒ Pull window crank -3- off drive.
Installing window crank 10.99 ä
Note:
◆ With the window closed the position of the window crank should be: a = 45° ±12°.
◆ The -arrow- in the illustration points in forwards direction.
‒ → Fit window crank in correct position on shaft.
‒ Secure window crank with screw and fit trim plate.
Edited by nige8021
To nige8021
Thanks for your help! I was going completely mad for a while. what an easy mechanism. Thanks again for your help
