noise near drivers side wheel?
hey there
the noise is a bang/wirring noise
increases with speed and quietens down with steering
the noise goes louder with speed aswell?
can anyone help?
  • Replies 9
  • Views 912
does the steering feel loose - does the car wander.. or does it wobble? could be worn track rod end or wheel bearing. if theres no visible damage and you haven't given it a hard knock it'll be one of those things. Jack it up and check for play between 9 and 3 o clock. if it only wobbles that way you have a worn track rod end sir.
sounds like the bearing kid
if it is a wirring noise then yes its bearing - its a bang noise then possibly not..
knocking noises can be the bearing,remember me thinking my gearbox was about to unhitch itself at one point,but was a bearing
does the noise change as you turn? for example louder on a left turn,but quiten when you turn a right? at speed
Edited by gaz2k
Mines doing exactly the same fella, and is doing exactly as gaz^ described haha. It knocks when pulling away, coming to a stop etc. and whirrs so loud when turning left that i cant hear myself talk......think its about time the bearings were changed... :lol:
hey guys, yea its a wirring banging, increases with speed then fades at high speed, returns as i slow back down, sounds like somethings going round and round following the motion of the wheels, is this deffo a bearing? am i right thinking these are dear to replace? i know driveshafts are abit exspensive arent they? these old polos give you some right probs haha, i also thought it was my gearbox loose haha :p I'm going to jack it up in the morning and investigate as best i can to my knowledge...which is minimal haha
thanks guys!
Id put my car on it being a wheel bearing mate, the whirring is classic symptoms. I got quoted 80 quid a side today but I'm sure you could find somewhere cheaper than that, just have a good look around :)
top man! i'll certainly shop around! thanks man, let us know how you get on in the end, hope you get yours sorted too!
hi all
just had my passenger front wheel bearing replaced
since my ride has been very bumpy
little bumps the front end sounds like its heavy as!
there is also play i think
the wheels are at 12 but the steering wheel is near 1!!??
has the bugger sent my tracking out or could there be more to it?>>
thanks in advance people!
