Refitting 8v bumpers help
Hi all, just re-fitted my 8v bumpers - back is fine. Just need a little help on the front.
Does the lower valance at the front mount over the mounting points or under? I think over but have done under and it looks wrong. Also, what fixings are used as standard?
Any help appreciated!
  • Views 797
Under mate, that's what I did with mine anyway...hope that's what you mean..as in the little bracket things that come down yes?
I did mine under and the brackets are then hidden by the lower valance :)
I think what you're saying is how I think I should have done it but didn't...
I have put the bracket attached to the bumper under the bracket attached to the car itself - this way the valance doesn't hide the brackets.
Have you got the brackets attached to the car under the brackets attached to the bumper/valance?
Also, what sort of fixings/fasteners have you got? Bolts/screws?
Yeah like that have the bumper lip over the cars mounting brackets! I've had my bumpers off so many times :) standard fixing is a few large headed torqx bolts... just need something with the same thread to bolt in!
hope that helps, Aaron
Nice one, thanks. Need to whip it off and put it back on right then!
