genesisGTs Squareback
My wee squarebacks been of the road for a while (08) as the charger poped an oil seal a while back so i took the engine out her and decided she was going to get some love.
So i bought a wee mk3 saloon which i enjoyed playing for a few years but decided to get back to my heck and finish it off properly.
She left the factory as a 1993 L plate 1.0L genesis Squareback and i bought her off a chap down in Stains London, who looked after her well so i am the 4th owner, others being the wee man, VW (ex demonstrator), and another chap who only owned her for a month or so after VW. She was bought to replace an identical Squareback i had and loved very much but unforunately died in an accident (twisted chassis legs). :crybaby:
For the last 3 years she has been living in my garage while i have been gathering parts off worldwide ebay, scrapped cars, VW and other vw specialists and anorak warehouses, and I'm at the stage where i have 75% (ross dont laugh!) of the stuff to give her the rebuild i have been wanting to do.
car she replaced RIP (i dont name my cars but it was know as ERMMMM)
Current Squareback as bought with previous owner in the pic...
heres is how she looked when i first convertied her to a G40 back in 2007...
Currently I'm stripping her down for a full respray so she looks rather sad at the moment living under her superman cape as one of my friends likes to call it, the floors are bare underneath all the tanks pumps lines removed etc most of what is left on her will be my spares and the new bits will go on instead.
Spec when she was last on the road in 2007 is below, but i hope change the OEM spec this time round as even i have to admit less is sometimes more, mechanically she will be almost the same spec with a few changes as whatever power she was producing i am happy with as u could get wheel spin in any gear and she picks up speed nicely considering the extra weight i have loaded her with, she is definatly more a comfy cruiser than a racer!
Engine spec:
Standard G40 internals cam and injectors
Jabba R1 charger & induction kit
Boost return mod
Stage 3 high flow head port matched to both manifolds
GT inlet manifold
Dewedged throttle body
flowed charger outlet elbow
currently a decat but will be fitting my PPP 4 branch front section.
Standard mid and rear box
Chipped ECU
PSD toothed pulleys
Standard intercooler
milage is just over 100K (shells about to turn 80K)
Power wise I'm not sure what’s she is running hope it would be about 150BHP.
Engine was rolling roaded about 6 years ago at 170bhp with 170lb-ft but it had a big exhaust and aquamist at the time so i know its down from that.
Chassis spec
Full GT/G40 running gear consisting off:
VWII brakes
FK -40 suspension kit with G40 bump stops
GT/G40 , rear axle, steering damper
Standard polo driveshafts and TCAs
Genuine accessories & OEM/OEM+ stuff is sort of my hobby :oops: so she has lots of them too, will type the list another day for anyone who is interested.
So i hope to make some decent progress on her this year and get her back on the road in 2012.
All bits loom switches are genuine unless stated.
ICE
JVC DVD headunit (tiny screen version)
JVC 12 disk text enabled CD changer
Home made boot built to house the above
4 ohm speakers front and back (standard are 3ohm) still shit though lol.
4 Tweeters 2 rear and 2 front (dummy cover the winder holes)
Reversing Colour camera (works but never drilled the bumper)
Audioscape door pods
3 Schabak polos and bling VW badge on the parcel shelf.
Current OEM MK3 polo bits
Armour door plates
Headlamp washers
Front fog lights and loom
Front and rear rubber VW mats with the polo badge insert
Sump guard
G40 clocks
Headlamp protectors
Battery cover
Heated screen washer jets and home made loom
Electric Headlight aim adjusters & RHD switch and loom (dash loom home made)
Sealed First aid kit (green script) and holder all contents well out of date!
Warning triangle and retaining strap
Boot sill protector
Electric window kit with the correct spal switches
Boot side carpets (early Velcro version)
Under bonnet insulation (fire blanket)
GT/G40 steering damper
Green tinted heat insulating glass (non bonded quarter lights)
50/50 split rear seats
Steel sliding sunroof
GT/G40 Rear axle
Hella Front indicators
Rear seat belt guides
Glove box door lock
Centre consol cassette storage with illumination
Leather G40 steering wheel with black trim
Dash trailer warning switch
Charcoal canister blanking plate
Full tool kit with all the clips, plastic tags, rubber bands
Front rear black VW badges
Front and rear G40 badges
Current OEM+ items
“polo” script door sill panels
Heated Seats (passat loom & switch)
Scirocco GTII seats (need the heated pads put in them)
Chrome door handle inserts
LHD all rear rear light and home made loom
Delocked passenger door handle
GT Grill panel rear insert (lets a bit more air at the charger than the standard 1.0L one
Door latch covers
Heko door wind deflectors
GT side indicator blanks
Washer bottle strainer
Black GT sunvisors and clips
Black sunroof controls
New OEM/OEM+ bits for 2012
Chrome and black Golf rear door handles (only if I can find a central locking kit)
Door handle finger plate inserts if the above is used.
Electric sunroof conversion kit loom and switch with mk2 golf internal dimming light
genuine loom for heated washer jets
Genuine loom for the headlamp washers and the 3 bumper clips.
Genuine 4 speaker loom and rear inner wing grommets, pads and inner wing clips
VW tyre compressor (blue version that can fit in the glovebox)
½ colour coded bumpers
Colour coded boot plinth
underbonnet light
French spec yellow front fog lights
Rear plastic speaker cages, with rubber speaker mounts
Squareback version foam pads for on the tailgate to stop it rattling.
GT/G40/CL dashboard (no holes round the glovebox)
Cigi lighter loom (never wired it up last time)
speedo cable clip that holds the cable neatly to the heater box (never seen it before but was on a low milage car i broke)
Front and rear mudflaps with the polo script badges
Mk3 golf rear boot catch with built in boot light actuator (home made boot lights using mk2 rocco bits)
GT/G40 Rear load sensor valve (didn’t fit it first time round)
Leather G40 full height gear gator and gearnob
G40 ARB driver side mount with the cut out for the charger belt
14” Rocco mkII steels and centre caps
256mm Audi brakes up front
GT/G40 radiator
Front wings with no side repeaters
Body coloured front and rear G40 badges
22mm brake master cylinder and LHD resevoir (square to match the rest of the car)
MK4 polo sump wiring holder (as the mk3 design is pants)
VW 14” space saver to fit over the 256mm brakes with genuine VW spacer to fit the mk3 boot.
VDO oil temp and pressure gauges and dimmer unit booster (never wired them up last time).
VW picnic blanket
Non charcoal canister models fuel pipe set up and breather
VW dealer bunting proper 1990s spec for round her at shows
Van boot sill trims Stainless Steel (unlikely to fit them)
Van safety net for behind driver and passengers heads with all the mounts and bolts (unlikely to fit them)
Radio volume adjuster linked to the Speedo (goes louder if you go faster)
VW headrest coat hanger
electric window switch & loom (as I make a loom and used mk2 golf ones last time).
Tow bar and proper loom to go with the Dash warning switch
PCT Towbar (least amount of drill holes into the shell and goes under the bumper)
New engine bits for 2012
PPP 4 branch manifold coupled to standard 50mm system
Cat cams Vernier pulley
Probably other stuff too but that’s most of it.
Wish list
Rear seat saloon headrests trimmed to match the rest.
Wiring loom for radio (anyone breaking a german genesis?)
central locking Kit
Cruise control
Edited by genesisGT
  • Replies 51
  • Views 12.3k
5 stars from me, one of my favourites. :thumbsup:
Cant wait for this list Richard :) Looking sweet and anal as ever ( The best way ) ;)
cheers chaps :-D
added the oem list
Are you after the speaker cages for the back? I have a pair...
Just read the spec list, nearly LOL'd when I read the picnic blanket!
Serious, serious dedcation. Love it.
you OEM whore :lol: going to look nice when finished.
Dont suppose you have pictures of the mk3 head light washers?
lol well if you ever need a picnic blanket for you are pimpin OEM old folks buggy at the polo show martin you know who to ask! they do a matching welly bag too but didnt know where i could fit it in.
cheers for the offer Alex :thumbsup: , but all the bits on the list i have except the wish list items at the end which i am still hunting for.
heres some pics of the headlamp washers on another post its missing the loom and the 3 bumper clips in those pics:
http://www.clubpolo.co.uk/forum/index.php?...eadlamp+washers
its my favourite accesory by far, as its like a chav face washing super soaker as they stand on the pavement.
Edited by genesisGT
Thanks mate, have started looking at scirocco ones to see if they can be made to fit.
love it richard
you are the king of oem
Awesome stuff. You need a tilt and slide sunroof from a rocco on that for sure!!
Mine will be finished before yours! :D
would love a rocco tilt and slide roof :nod: but most you see are fecked, bits missing, leaky or over £100 :-( and the scrappy near me never have any in.
I should hope so Andy! no excuse for it not making the polo show this year. ;)
I love soaking people too, best enhancement i've done to my car!
mine are working tooo drenched me sister with them on sunday lol
Look forward to seeing this done Richard, bags a ride in it too ;), or maybe not as i'll want a G then :lol:
With your obsessive attention to detail it sounds like this could be an entrant for a modified concourse show :-)
Headlamp washer soaking should be a sport! Good man chris lol bet your sister appreciated it!!
can get a run I'm it mark yeah but you then want one that's what happened to me. Mine should be a Q plate I think.
Ironically out the different Mk3 polos I have owned over the years this one has never been to a polo show :-(
as it was nice and sunny today started to mock up the bits make sure they fit and cut the headlamp washer adn fog holes in the front bumper as i have been putting it of as do it wrong and thats alot of £££ down the drain for a new colour coded bumper. So please to say it went ok with only minor extra filing needed.
the back bumper was a bit distorted from living up my loft for about 2 years so bit of bending and bashing and got it bolted down, so will leave it a few days try make it bend back into shape.
Stripped out some more of the interior so the floors look good just the battery tray needs a 2" square welded in but its right on the curve :roll: , will change the tailgate tomorrow as mine is rusting from the inside out :-( the feed wire into the tailgate is to big to get out the hole on the C pillar so think i might have to cut the connector so i can get the pins out. as i cant see anyother way to get it out in tact. :?
anyway was nice to see her looking like a polo even breifly with her "Face" back on.
pics form today:
did a wee bit after dinner tonight,
just got the washer tubing cut to size and all in place neatly and the wee clips on. finally found out the 3 recesses in the bumper are for the clips always wondered as if its got an extra hole or space that usually = vw do something to fit in it. so in an anoraky way that made me happy lol :-D
then fitted the twin horns and wee bracket.
Edited by genesisGT
Yellow fogs are the sex. Please sell them to me.
did a wee bit more:
let the car sunbath for an hours or so then carefully removed the roof gutter trims are the are 100% obsolite and can snap easy when they are cold. then started picking unsticking some of the headliner but will need to wait till i get the sunroof and windows out to do it properly.
got the new tailgate on and almost fully lined up, its a tiny bit low at the top left but seems to have no more adjustment so think a file is needed to the hinge.
then got the remaining wiring out her so only the interior light loom left and gave it a hoover out.
only rust found so far is the battery tray which i knew about 2 wee specs under the door rubber and i know the overflow pipe at the fuel tank end is starting to go under the rear seat so hope there is no more.
next jobs get the front wings off i think been putting it off as the sealer stuff sucks down the back edge.
Where did you get the mudflaps from? They look spot on.
Thanks I like them too. They are out my local partco, think eBay does them too. They are £10 a pair and come with the mounting screws you just need to drill a few new holes in them so they sit nice on the body. The wee vw logos are well printed mine are 4 yo and still look pretty fresh so would recommend them.
Edited by genesisGT
not done much else to the shell worth reporting, so today drilled and modified my dashboard to fit some more oem stuff. i wanted to fit & check the wiring looms were long enought to get to where they need to go so most seem ok.
the bodyshop mans coming to visit on the 18th to give me a quote for repainting her so will see how it goes, so should have the wings, glass, headliner out by then and that means i can try mocking up the sunroof kit yay - will do a wee video when it works.
Dash now has all the OEM extras i wanted: heated seats, trailer light, headlight beam adjusters, sunroof switch, leccy windows, G40 speedo with the radio inductive volume sender, locking glovebox door and the aftermarket bits: Yoof black box airflow ratio meter, boost gauge, and VDO gauges in the centre consol with the Full height leather gear gaitor, uprated speekers with built in tweeters.
heres some pics:
and got some new bits from germany, the wee speedo volume thing (wiring appears to be built in to all dash looms) so will try work out which wire i need to connect to my JVC non original head unit haynes book of lies seems to say its there!
Edited by genesisGT
you are the OEM king!
are your flaps like this?
http://cgi.ebay.co.uk/VOLKSWAGEN-MUDFLAPS-...66#ht_589wt_667
I bought some a while back that were different to this. very floppy and they hang really awful?
want to replace them with some like yours but want the right ones :)
