Saab 900 vac advance distributor
As titled, perfect working order. A late mk2 polo or mk2 golf ignition amp and loom plugs straight into this to switch to electronic ignition 8-)
Pictured here fitted to my mk1 Golf.
£25 posted
Thanks,
Arun
  • Views 266
How is this different to a standard mk2 dizzy?
didnt know these were usable, got a box load of 900 parts lying around.
They have a hall sender which the ignition loom from a late mk2 will plug straight in. So you can convert your solid lifter engine to electronic ignition and still retain vacuum advance :-)
VW KR engine dizzys also fit but have no vac advance.
while were on the subject of dizzy's, Hyundai S Coupe dizzy cap will fit too, so all your connections face back and not out towards the side, if theres an engine cover then the leads are hidden.
