Rolling/Flaring Plastic arches?
Basically a mate has a new shape beetle and literally rubs everywhere he goes is there anyway to sort this without replacing the whole arch?
Any help appreciated,
Steve
  • Views 1.6k
Nobody!?
Nicely cut the inside arch out, which will give it a rolled effect. :) Are they seriously plastic?
Its from a new shaped beetle, there a right pain in the arse tbh but it rubs so he doesnt get the arch cutting through the tyre like on polo's
199237_10150435772720524_527825523_17731
Edited by stevemk3
Try using a heat gun and slowly warm the plastic up (not so hot that the pait bubbles and melts) just to get the plastic a bit more flexible, then use a metal tube and put it between the tire and arch and drive the car really slow and put a little pressure on the arch with the tube. This should push the arches out alittle. But I would say get somebody who works on body work to do this, since it can go wrong very easy.
Cheers mate, we'll have a go ;)
