mk2 wing
okay, so i've got a new wing to replace my dented one, i've tried to see how it's attached but i can't see behind =P
from one i can see, it's mainly bolts, but there's a bit of welding under the bonnet, but i need to know if there's any other welding?
also, how is best to "unweld" stuff?
Tah
  • Views 717
There shouldn't be any welding, just a row of bolts along the top, a row down the back of the wing (go in from the wheel arch), coverred in underseal, and a big fat screw at the front.
Just take your old one off, if you don't need a saw or a drill to remove the welds then it isn't welded :) but I have bought a car before where the previous owner changed the wind and had lost all the screws so he had welded it in place. But the chances of somebody been that stupid isnt much ;)
A heat gun can be useful to soften the sealer once that you have the bolts out, just warm up the joint and keep pulling!
