How to pull out the wipers water tank ?
My wiper's water tank is leaking bad, water is sliding straight down under it... I can see the 2 top screws that hold it but even after removing them it doesnt budge.
Any ideas ?
This is a 6N btw.
Edited by MK3Dawg
  • Views 789
Windscreen washer system
Removing windscreen washer system reservoir
‒ Removing battery => Page 27-30.
‒ → Pull off hose -1- to windscreen washer jets and hose -2- to rear window wash system at pump.
‒ Pull connector off window washer pump.
‒ Undo plastic nuts -arrows-.
‒ Take reservoir out carefully upwards.
This couldn't be any bettter thank you very much !!!!
Yeah the third one may be accessible without moving the battery,but when i swapped the 2L one on the wife's 6n for a 2.5L one i had to move the battery.
Being only plastic,the fixings are easy to round-off. Use a six sided socket,not a twelve sided one,if you're going to brave going at it at an angle.
