mk1 golf gti cabby project
i got this out of abarn it was going to be scraped
stared on the welding today
iv welded the lower val in today
it still needs to seam welding and panel beating and it needs a wheel arch to
Edited by gazz
  • Replies 10
  • Views 1.9k
iv made all the repair panel out sheet metal
iv finished the arches ? i just gave it the first skim of filler to stop the rust for a bit
i found more rust today :x
the wheel well was roturn so cut it out I'm going to weld in a new floor and battery tray
Oooh dear! Seems like it could be a fair bit of work this one, but fair play to you for rescuing a forgotten dub :) Keep up the good work
got sick of the back end? so started on the front got rid of wiper hole and aerial
all i need to do is weld the new rear floor and it will all welded up
then i can start on the paint
Edited by gazz
started on the the boot floor
i made template just need some steel and i start
got the floor in to day just needs welding in and the batery box made and side bits made
did a bit more this week
oh and got new project
Great work fella :smile: Keep plugging away at it and you'll eventually have a mk1 that you know inside out, and be rid of the rust!
i got bit more done
welded in the batery box and made the corner bit
