Mk 2 towbar fitting help
Ok I get most of it, 2 holes in the top, 2 further down in the middle and 2 for the bars to the chassis legs. What I need to know is what the spacers and flat plates are for
Anyone got a pic of one fitted? would really help.
Edited by hammerong
  • Replies 16
  • Views 1.9k
looks like the propper westfelia one or a bosal copy :nod::thumbsup:
for the fitting instructions click the wee blue spanner:
http://www.catalogue.bosal.com/pages/tow_c...0&year=1993
the westfalia ones on the web to just go to their website.
sure the plates go on the "U" shaped mounts where the body was carried along the production line. either that of they go inslide the boot floor but it is higher up i think.
powder coat it before you fit it will look pimpin.
Edited by genesisGT
This looks like a bosal one, the Westphalia ones are same design but they are over-engineered to death. :lol:
flat plates fit under the chassis loops, line up those long bars and they should reach a U section either side, bars fit through the U plates, flat plates go on the underside of the U, bolt up. the spacers are supposed to be for fitting to breadvans but they look too small (compared to the Westphalia ones)
plate fitting:
^^^^You can see the spacers in Coupe mode, for a breadvan they go between the bar and body.
Have you got the re-enforcing L plates that bolt inside the boot?
L-plates:
Mine:
(B-shaws photo's from his original sale thread for my towbar)
Edited by Cymro
Cheers mate, the spacers fit in the holes of the chassis loops and would raise it to the right height but I didn't have bolts long enough so just left them out for now.
No L brackets but the standard bumper brackets are kinda L shaped so it bolts onto them ok. If I tow something and it rips out then I guess they weren't strong enough.
This didnt have any L plate bits when it came on my car and it was mounted through the Chassis rail on mine in the boot on the floor there are some plastic covers over holes the ones closest to the turret had the plastic covers taken out the round spacers put into the hole and the plates put on the top and the bolts were put through and bolted to the plates underneath the car and then to the angle plate which was against the rear sill underneath the car and then the main towbar bolted through the rear sill into the angle iron bit and the bumped bolts went through weither end of the towbar and into the car where the nuts were screwed on. thats how it was fitted to my bready if you understand what i put lol. and hope it got to in well hammerong packing was a bit mish mash but its all i had.
Yes mate, arrived fine, was about to drop you a PM to say so. PAckaging was great, took me longer to unpack it than it did to fit it. There must've been a whole roll of cling film and 4 rolls of electrical tape on that.
but it was obviously fitted to mine wrong then that looks right in the photos and i dont think this is a bosal one as it looked very old and has the vw stamp on it and the original hella trailer wiring plug sockets fitted to it.
cool thats good then didn't want it getting damaged and hope it cleans up and paints well i got the gf to wire brush it all for me before i packaged it and i didn't have any normal tape just some extra wide insulation tape i robbed from my old work lol
Could be that the mk2 had a bit more re-enforcing already in it and by the mk3 they revised the design.
According to the documentation the max tow weight for mine is a 1000kg. which if you calculate is not only uk illegal but more than the car itself weighs. :lol:
and it has been used a few times with a towbar mounted winch to get my car out of the drive in the snow :lol:
Edited by Cymro
I'm not that worried, the most I'll tow is 1/4 tonne. The bolts I used are good for 55 tonnes each iirc so the weak point will be the car itself.
Check your licence before you tow anything, as new licences do not automatically cover you for towing you need to have category B+E if not and you get pulled it's an automatic 6 points!!!
I thought that was only for over 3.5 tonnes. I wish they'd leave the categories alone.
http://www.direct.gov.uk/en/Motoring/Drive...ions/DG_4022547
Edited by hammerong
The only reason I posted that was, one of the bar staff in my local passed her test, and then set off in her dad's Mitshi Shogun with her horse in double horsebox, got pulled for a very minor traffic indiscretion, and when she explained she had only just passed her test and could they go lightly on her, thats were it went downhill fast, as her new licence did'nt cover her, so she ended up with a court apperance and a £120 fine and 6 points on her fresh licence so she lost it !!
I know there are certain restrictions for towing, like the all up weight of the vehicle and trailer and just the trailer, also how old you are and when you passed your test, you almost need to have a lawyer in the passenger seat to make sure your OK when stopped by plod!!
I know what you mean, and half the time the cop that pulls you doesn't understand the law. The website I posted is a bit vague, but as I read it it's ok for total weight of 3.5 tonnes on the new cat B.
I'm gunna go into my local station, ask if I can or not, and ask for it in writing.
I've been told that on the new licences you can only pull a trailer totally loaded up weighing max of half a tonne and no more than the car thats towing it and it has to be a non braked small trailer of a certain size on a single axle and thats from quite a reliable friend who has to tow alot for his job and has a newish type licence.
hope this helps
Stuff that, mine covers motorcycles,trailers, 7.5 ton trucks and my test was two minutes around the block followed by three questions :smirk:
What a great government Labour have proven to be.. Cocks.
Yes anyone who passed their test prior to 1997 has a greater coverage of vehicles that you can legally drive
