Open air - bent sun roof
This morning I had a perfectly good, tight fitting sunroof on my newly bought '99 Polo Open Air - good that is apart from the finish trim that spends most of its time dangling in front of the mirror.
With other jobs on the car taking priority in the good weather, clever me thought I would peg it out of the way as I drove into town with the sunroof down - then shut the roof without removing the peg. The result is one bent sunroof that now pops the guide blade and no longer sits flush on one side meaning that the next downpour will result in a very wet car.
I have just spent a walletfull (worth it - my first Polo and, till today, loving it) on getting the thing back together and roadworthy so am hoping this isn't going to cost me another one to put right. Any advice greatfully received.
If you can't bend it back then its a case of finding a good second hand replacement really. When I was looking for one for mine I found a website called carhood.com that does a replacement for £185+ VAT, but then I went down to a local trimmers and they said they would make me a new roof for £150.
I never got it done in the end, but if you are going to go for a 2nd hand one, good luck, they all seem to have split at the back.
Thanks for that. I'll have a look with a fresh head tomorrow, but tugging and heaving got me nowhere today, so guess I'm going to have to bite the bullet and replace it. Let's hope it doesn't rain till payday! Expensive peg eh?
  • 5 months later...
Thought I'd add a postscript to this: Been very patient since April relying on good weather, gaffer tape, a car cover and prayer to stay dry (thank god for the driest spring in years - could've done with a decent sunroof though, oh the irony!) whilst looking for a decent replacement on ebay or elsewhere. Saw a few come and go at silly money or pick up only - not easy when you live on an island.
Eventually found one on Ebay at the end of August - £115 with postage - and fitted it last weekend.
Fitting is dead easy - I had the roof lining and old roof out in just over the hour. Putting the new one in took longer as I took the opportunity to clean up all the metalwork around the rim and fit a new gasket to the radio aerial whilst the headlining out. Also discovered the old roof had been a replacement itself and was missing mounting screws and a water seal, which I put right. The replacement is a better roof than the old one, has no splits and is now fitted properly - result! - and worth the wait even though it has not stopped raining since I fitted it.
The old roof I will strip down, work out how it works and try to fix so that I have a replacement in hand.
I guess the point of this is that there are still some decent second hand Open Air roofs out there and fitting yourself is easy if you've got basic skills and tools. If you've got a good frame but a split roof try your local trimmer - my local trimmer advised me how to get the roof lining out and offered to re-cover the roof if I needed it.
