headlining re-trimming
i re-trimmed my headlining headlining in black about 2 weeks ago, i used heavy duty spray adhesive looked great and i thought it had stuck well but got into my car last night after work and the headlining had come unstuck :( has anyone else had this problem and what glues/adhesives have you used before that have worked?? help please :D
  • Views 868
With most of these petroleum based adhesives, you need to coat both surfaces and then allow it to dry before bringing the two parts together.
If all else fails, you could try first of all coating both surfaces, allowing it to dry and then applying double sided carpet tape to the head lining and then pressing the other side of the tape (after removing the backing of course) to the inside of the car.
You can get both adhesive and tape from B&Q.
Regards.
ahh thats where i went wrong then i sprayed it on then stuck it down straight away!! ill have to get fresh material then have another try at it, thanks a lot mate :)
I used trim fix good stuff but verry messy :D
