6n2 gti breaking
Had a clear out of the shed today and came across some bits i had left from my gti 6n2 i was breaking awhile back. All parts came of a 2001 polo gti with 45000, just looking rid of all this stuff so any reasonable offer for anything will be acccepted.
Full cylinder head with camshafts etc
p/s door lock
water pump (practically new was only in the car a few months)
lambda probes
slip ring
3 geniune speakers
front wiper linkage and motor
steering column
flywheel
clucth and pressure plate (geniune and practically new was only in car a few months)
engine mounts
driver and passanger airbag
convienabce locking control unit
heated rear window switch
climantronic control panel
p/s window motor
starter motor
alternator
exhaust manifold
ignition coil
power steering pump
auxiliary housing mount
evap filter
driveshafts
Catalytic Converter
brake servo
power steering bottle
front brake calipers
fan
air con radiator
  • Replies 46
  • Views 2.7k
Do you have the part that mounts beneath the manifold that runs to the cat? Basically that flexible pipe?
Have you got the GTI Splitter mate?
PM if you have.
Cheers.
Hi mate.
I need the bit of trim that covers the headlight washer jet on the right side.
PM me if it's available please :)
only the part on the list are avaiable everything else is gone
bump
Steering wheel & airbag posted to glasgow?
G
how much for the climantronic control panel?
Pmd
bump
Bump
p/s door lock
lambda probes
slip ring
3 geniune speakers
steering column
flywheel
engine mounts
p/s window motor
starter motor
alternator
exhaust manifold
ignition coil
power steering pump
evap filter
driveshafts
Catalytic Converter
brake servo
fan
air con radiator
bump
do you have the centre/middle pipe from the exhaust?
pm me if you have please
cheers
jay
How much for the ignition module and ht leads? And picture please with all the connectors in place not broken.
do you have the level sensor ffor the headlights?
Also does it come with headlight washers?
Do you still have the front splitter, drinks holder?
dnt have center exhaust, level sensor, or frontsplitter just whats on the list
bump
p/s door lock
lambda probes
slip ring
3 geniune speakers
steering column
flywheel
engine mounts
starter motor
alternator
exhaust manifold
power steering pump
evap filter
driveshafts
Catalytic Converter
brake servo
fan
air con radiator
bump
£15 for each item plus postage except the cylinder head
Received my coil pack yesterday mate thanks.
bump
Rear door cards?
Prabs
Rear door cards?
Prabs
dont have
