6n2 gti breaking
Full cylinder head with camshafts etc
p/s door lock
water pump (practically new was only in the car a few months)
lambda probes
slip ring
3 geniune speakers
front wiper linkage and motor
steering column
flywheel
clucth and pressure plate (geniune and practically new was only in car a few months)
engine mounts
driver and passanger airbag
convienabce locking control unit
heated rear window switch
climantronic control panel
starter motor
alternator
exhaust manifold
power steering pump
auxiliary housing mount
evap filter
driveshafts
Catalytic Converter
brake servo
power steering bottle
front brake calipers
fan
air con radiator
  • Replies 46
  • Views 2.7k
bump
Take it throttle body is sold? If not, price posted via special delivery / next day courier to kt92pu please :)
Is there the cup/coin holder ?
p/s door lock
lambda probes
slip ring
3 geniune speakers
steering column
flywheel
engine mounts
starter motor
alternator
exhaust manifold
power steering pump
evap filter
driveshafts
Catalytic Converter
brake servo
fan
air con radiator
n/s wing mirror
dont have . Only have whats on the list
bump
gear knob and gaitor?
How much postage is it for drive shafts to london , really interested but think it be a arm and a leg
How much for the heated rear window switch?
You got the doorcards? Also the plastic Surround which covers the Steering column and ignition?
whats the condition of the front break callipers?? maybe interested
alright mate. I'm interested in the driveshafts and exhaust centre section. could you give me a price posted. and were are you based?
pm the an answer please mate
cheers
jamie
How much for lambda and passenger side speaker? Pm me if you like dude?
bump
how much for the head posted?
did it run good before removed? no smoke etc?
pmd
How much for drivers side caliper carrier and slides Inc postage?
Edited by steviedubs
p/s door lock
lambda probes
slip ring
3 geniune speakers
steering column
flywheel
engine mounts
starter motor
alternator
exhaust manifold
power steering pump
evap filter
driveshafts
Catalytic Converter
brake servo
fan
air con radiator
did you get my last pm mate?
I'm not sure if there are limits on this forum as to how many you can send per day but i may have got to that point if it is resctricted :crybaby:
Pmd mate
